Creating a new table
Creating tables
To learn about other types of data sources you can use in tables, see Creating new tables and About tabular data sources.
Create Table
| Importing, copying, and converting tabular data sources |
Importing tables
An overview of adding datasets to the geodatabase
To learn about the importing process and the geodatabase, see How data converts when importing.
Table To Geodatabase
Table To Table
Table To dBASE
Copy Rows
| Adding fields |
Adding and deleting fields
To learn about fields and their data types, see Geodatabase field data types.
Add Field
Delete Field
| Displaying tables |
Adding and viewing tables in ArcMap
Previewing a table in ArcCatalog
Setting field properties, aliases, and table display options
Make Table View
| Creating associations among tables such as joining, relating, and using relationship classes |
About joining and relating tables
Joining tables
Relating tables
Relationships and ArcGIS
Deciding between relationship classes, joins, and relates
Add Join
Remove Join
Create relationship class
| Editing attribute values |
Editing values in a table
Editing attributes
| Calculating the values in fields |
Making field calculations
Working with date fields
Calculate Field
Printing tables
Printing a table
Creating a layer from a table with x,y coordinate data
Adding x,y coordinate data as a layer
Make XY Event Layer
| Using
An overview of linear referencing
An overview of the Linear Referencing toolbox
a table of addresses
An overview of geocoding
An overview of the Geocoding toolbox
