Creating the geoprocessor object |
Release 9.3
Last modified June 3, 2010 |
Print all topics in : "Accessing tools within a geoprocessing script" |
This topic was updated for 9.3.1.
ArcGIS 9 introduced a scripting object, GPDispatch, that could be used in scripting languages such as Python, VBScript, and JScript. A common object model based on objects supporting IDispatch was created to provide a uniform scripting experience. However, this meant none of the unique capabilities and strengths of a particular scripting language were utilized by the geoprocessing object.
ArcGIS 9.2 introduced native Python support for geoprocessing scripting. Instead of relying on Python's win32com module to create the geoprocessor, the geoprocessor could be created using a new native arcgisscripting module. This change provides the flexibility to use Python geoprocessing scripts on a variety of platforms, instead of being limited to Windows operating systems. The arcgisscripting module also provides some IntelliSense capabilities. Server tasks can only be performed using the arcgisscripting module.
Over the past several releases, users have overwhelmingly selected Python as the scripting language of choice. At 9.3, a further enhanced native Python geoprocessing object was introduced to accept and return common Python structures such as lists and Booleans. This creates an experience for geoprocessing that is richer and more consistent with standard Python use. The 9.3 geoprocessor can be created using an optional version argument with the create method on the arcgisscripting module. The behavior of existing scripts that create the geoprocessor without setting the version will be unchanged.
All geoprocessing Python scripts can import either the arcgisscripting or win32com modules to instantiate the geoprocessor object. The examples below illustrate the difference. The arcgisscripting module is built closely upon Python 2.5.1 and requires this version to create the geoprocessor. Scripts can be run on different versions of Python if they use win32com to create the geoprocessor.
9.3-version geoprocessor
# Create the geoprocessor using the arcgisscripting module using
# 9.3 for the optional version argument
import arcgisscripting
gp = arcgisscripting.create(9.3)
gp.workspace = "c:/Tongass"
gp.clip_analysis("standb4", "clipcov", "standb4_clip", "POLY", "1.25")
gp = arcgisscripting.create()
# Create the geoprocessor using the win3com.client module
import win32com.client
gp = win32com.client.Dispatch("esriGeoprocessing.GpDispatch.1")
Python lists versus enumerations
For Python scripts with a geoprocessor version of 9.3 or greater, list methods (e.g., ListFeatureClasses, ListDatasets) return a true Python list object. With a 9.2-version geoprocessor, these methods return an enumeration object. With a 9.3-version geoprocessor, the following methods return a Python list: ListTools, ListEnvironments, ListToolboxes, ListFeatureClasses, ListDatasets, ListTables, ListRasters, and ListWorkspaces.
A Python list provides the opportunity to use and manage the results of a list function in a variety of ways. A list is a versatile data type and provides a number of methods (append, count, extend, index, insert, pop, remove, reverse, and sort) that can be used to manipulate and extract information.
The following examples contrast the differences between using ListFeatureClasses with a 9.3-version and 9.2-version geoprocessor.
9.3-version geoprocessor | 9.2-version geoprocessor |
| List method code example |
# Use 9.3 for the optional version # argument # gp = arcgisscripting.create(9.3) gp.Workspace = "c:/data" # List function returns a # Python list # fcs = gp.ListFeatureClasses() print fcs # Step through a Python list # using a while loop # for fc in fcs: print fc |
gp = arcgisscripting.create() gp.Workspace = "c:/data" # List function returns an # enumeration # fcs = gp.ListFeatureClasses() print fcs # To get the next feature # class, you must use the # Next method # fc = fcs.Next() # Step through an enumeration # using a for loop # while fc: print fc fc = fcs.Next() |
| Expected results | [u'counties.shp', u'roads.shp']
counties.shp roads.shp |
<geoprocessing list object …>
| Tool return values example |
import types # Use 9.3 for the optional version # argument # gp = arcgisscripting.create(9.3) # AddField returns a result # object # result = gp.AddField( "c:/data/fc.shp", "flag") # Use the result object's # GetOutput method to # get a unicode print result.GetOutput(0) # The result object has a # several other methods # and properties # Print the last message # Print the tool status # print result.GetMessage( result.MessageCount-1) print result.Status # 4 indicates 'Succeeded' |
import types gp = arcgisscripting.create() # AddField returns a string # result = gp.AddField( "c:/data/fc.shp", "flag") print result |
| Expected results | c:/data/fc.shp
End Time: Wed May 30 15:17:12 2007 (Elapsed Time: 0.00 seconds) 4 |
c:/data/fc.shp |
| Boolean example |
import arcgisscripting # Use 9.3 for the optional version # argument # gp = arcgisscripting.create(9.3) fc = r"C:\geometry.gdb\fc" # Create a describe object from # a feature class # desc = gp.describe(fc) # Get the extent property from # the describe object # extent = desc.extent # Extent returns an extent object # Print some of the extent # properties (others include # MMin, MMax, ZMin, ZMax, # Height, Depth # print ("XMin: %f") % extent.xmin print ("YMin: %f") % extent.ymin print ("XMax: %f") % extent.xmax print ("YMax: %f") % extent.ymax print ("Width: %f") % extent.width # Return a point object for the # lowerleft point of the extent # (lowerright, upperleft and # upperright are also available) # lowerleftPoint = extent.lowerleft # Print the x, y coordinates of # the lowerleft extent print ("LowerLeft point X: %f") % lowerleftPoint.x print ("LowerLeft point Y: %f") % lowerleftPoint.y |
import arcgisscripting gp = arcgisscripting.create() fc = r"C:\geometry.gdb\fc" # Create a describe object from # a feature class # desc = gp.describe(fc) # Get the extent property from # the describe object # extent = desc.extent # Extent returns a space- # delimited string of coordinates # print ("Extent: %s") % desc.extent |
| Expected results | XMin: -21465.218971
YMin: 98376.566253 XMax: -3263.051632 YMax: 113087.882679 Width: 18202.167339 LowerLeft point X: -21465.218971 LowerLeft point Y: 98376.566253 XMin: -21465.218971 YMin: 98376.566253 XMax: -3263.051632 YMax: 113087.882679 Width: 18202.167339 LowerLeft point X: -21465.218971 LowerLeft point Y: 98376.566253 |
Extent: -21465.2189714847 98376.5662526509 -3263.05163221594 113087.882679454 |
| Boolean example |
# Use 9.3 for the optional version # argument # gp = arcgisscripting.create(9.3) gp.OverWriteOutput = True # Overwriteoutput returns a # Boolean value # print gp.OverWriteOutput |
gp = arcgisscripting.create() gp.OverWriteOutput = True # Overwriteoutput returns a # 1 or 0 # print gp.OverWriteOutput |
| Expected results | True | 1 |
# ASCII string # fc = 'river.shp' # Unicode string # fc = u'river.shp'
Although Python is the most commonly used scripting language for geoprocessing, geoprocessing scripts can also be created in a number of other script languages such as Perl, VBScript, and JScript. The following examples demonstrate how to create the geoprocessor, set the workspace environment, and run the Clip tool in different languages.
Perl example
use Win32::OLE;
my $gp = Win32::OLE->new('esriGeoprocessing.GPDispatch.1');
$gp->workspace = "c:/Tongass";
$gp->clip ("standb4", "clipcov", "standb4_clip", "POLY", "1.25");
Set gp = WScript.CreateObject("esriGeoprocessing.GPDispatch.1")
gp.clip "standb4", "clipcov", "standb4_clip", "POLY", "1.25"
var gp = WScript.CreateObject("esriGeoprocessing.GPDispatch.1");
gp.workspace = "c:/Tongass";
gp.clip ("standb4", "clipcov", "standb4_clip", "POLY", "1.25");
