Reading geometries |
Release 9.3
Last modified June 3, 2010 |
Print all topics in : "Data properties and access when scripting" |
This topic was updated for 9.3.1.
Each feature in a feature class contains a set of points defining the vertices of a polygon or line or a single coordinate defining a point feature. These points can be accessed using the geometry object, which returns them in an array of point objects. The array object can contain any number of geoprocessing objects such as points, geometries, or spatial references.
| Count | The number of objects in the array |
| Reset() | Resets the array to the first object
NOTE: Reset is used only for non-cursor Arrays. Using reset on a cursor Array will not reset to the first record. |
| Next() | Returns the next object in the array |
| Add(Object) | Adds an object to the array in the last position |
| Insert(Index, Object) | Adds an object to the array in a specific position |
| Remove(Index, Object) | Removes a specific object from the array |
| RemoveAll() | Removes all objects and creates an empty array |
| Replace(Index, Object) | Replaces an object by index position |
| GetObject(Index) | Returns a specific object from the array |
| ID | A long value used to uniquely identify the point |
| X | The horizontal coordinate of the point |
| Y | The vertical coordinate of the point |
| Z | The elevation value of the point |
| M | The measure value of the point |
Search cursor on a point feature class
# Import native arcgisscripting module
import arcgisscripting
# Create the geoprocessor object
gp = arcgisscripting.create(9.3)
infc = gp.GetParameterAsText(0)
# Identify the geometry field
desc = gp.Describe(infc)
shapefieldname = desc.ShapeFieldName
# Create search cursor
rows = gp.SearchCursor(infc)
row = rows.Next()
# Enter while loop for each feature/row
while row:
# Create the geometry object 'feat'
feat = row.GetValue(shapefieldname)
pnt = feat.GetPart()
# Print x,y coordinates of current point
print pnt.x, pnt.y
row = rows.Next()
2.0 4.0 8.0 10.0 7.0 5.0
Search cursor on a multipoint feature class
row = rows.Next()
while row:
# Print the current multipoint's ID
print "Feature " + str(row.getvalue(desc.OIDFieldName)) + ":"
partnum = 0
# Count the number of points in the current multipart feature
partcount = feat.PartCount
# Enter while loop for each point in the multipoint feature
while partnum < partcount:
# Get the point based on the current part number
pnt = feat.GetPart(partnum)
print pnt.x, pnt.y
partnum += 1
row = rows.Next()
Feature 0: 3.0 8.0 4.0 4.0 6.0 6.0 Feature 1: 5.0 9.0 8.0 10.0 Feature 2: 9.0 5.0
Search cursor on a polygon or line feature class
row = rows.Next()
while row:
partnum = 0
# Enter while loop for each part in the feature (if a singlepart feature
# this will occur only once)
# Print the part number
print "Part " + str(partnum) + ":"
part = feat.GetPart(partnum)
pnt = part.Next()
pntcount = 0
# Enter while loop for each vertex
while pnt:
print pnt.x, pnt.y
pnt = part.Next()
pntcount += 1
# If pnt is null, either the part is finished or there is an
# interior ring
if not pnt:
pnt = part.Next()
if pnt:
print "Interior Ring:"
partnum += 1
row = rows.Next()
Feature 0: Part 0: 3.0 8.0 1.0 8.0 2.0 10.0 3.0 8.0 Feature 1: Part 0: 5.0 3.0 3.0 3.0 3.0 5.0 5.0 3.0 Part 1: 7.0 5.0 5.0 5.0 5.0 7.0 7.0 5.0 Feature 2: Part 0: 9.0 11.0 9.0 8.0 6.0 8.0 6.0 11.0 9.0 11.0 Interior Ring: 7.0 10.0 7.0 9.0 8.0 9.0 8.0 10.0 7.0 10.0
