Show Navigation | Hide Navigation
You are here:
Map projections and coordinate systems > Supported map projections
Double Stereographic
Release 9.3
Last modified October 21, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Supported map projections"
Related Topics
A conformal projection.
Illustration of a Double Stereographic projection
Projection method
Planar perspective projection, viewed from the point on the globe opposite the point of tangency. Points are transformed from the spheroid to a Gaussian sphere before being projected to the plane.
All meridians and parallels are shown as circular arcs or straight lines. Graticular intersections are 90°. In the equatorial aspect, the parallels curve in opposite directions on either side of the equator. In the oblique case, only the parallel with the opposite sign to the central latitude is a straight line; other parallels are concave toward the poles on either side of the straight parallel.
Point of contact
A single point anywhere on the globe.
Linear graticules
Polar aspect—all meridians.
Equatorial aspect—the central meridian and the equator.
Oblique aspect—the central meridian and parallel of latitude with the opposite sign of the central latitude.
Properties
Shape
Conformal. Local shapes are accurate.
Area
True scale at center with distortion increasing as you move away from the center.
Direction
Directions are accurate from the center. Local angles are accurate everywhere.
Distance
Scale increases with distance from the center.
Limitations
Normally limited to one hemisphere. Portions of the outer hemisphere may be shown, but with rapidly increasing distortion.
Uses and applications
Used for large-scale coordinate systems in New Brunswick and the Netherlands.
Parameters
Desktop
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
