Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Coverage toolbox > Analysis toolset > Overlay toolset > Tools
Union (Coverage) (ArcInfo only)
Release 9.3
Last modified December 29, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
NOTE: This tool only works with an ArcInfo license and will only be available in ArcToolbox if you have installed ArcInfo Workstation.
Computes the geometric intersection of two polygon coverages. All polygons from both coverages will be split at their intersections and preserved in the output coverage.
Learn more about how Union works.
Illustration
Union Illustration
Usage tips
Command line syntax
An overview of the Command Line window
Union_arc <in_cover> <union_cover> <out_cover> {fuzzy_tolerance} {JOIN | NO_JOIN}
Parameter Explanation Data Type
<in_cover>
The coverage whose polygons will be combined with the union coverage.
Coverage
<union_cover>
The union coverage whose polygons will be combined with the input coverage.
Coverage
<out_cover>
The output coverage that will be created containing the results of the operation.
Coverage
{fuzzy_tolerance}
The minimum distance between coordinates in the output coverage. By default, the minimum fuzzy tolerance value from the input and erase coverages is used. Learn more about how the default fuzzy tolerance is calculated.
Double
{JOIN | NO_JOIN}
Specifies whether all items in both the input and the union coverages will be joined to the output coverage feature attribute table.
  • JOIN — All items from both coverages will appear in the output coverage feature attribute table. If duplicate item names are encountered, the item in the input coverage will be maintained, and the one in the join file will be dropped. This is the default option and is used unless NO_JOIN is specified.
  • NO_JOIN — Only the feature's internal number (cover#) from the input coverage and the union coverage are joined in the output coverage feature attribute table. This option is useful in reducing the size of the output coverage feature attribute table. The cover# field can then be used in the Add Join tool to link the features in the resulting coverage back to the features in the input or union coverage.
Boolean
Data types for geoprocessing tool parameters
Command line example
union_arc h:\workspace\soil h:\workspace\timber h:\final\tiber_soil_un 0.0003 NO_JOIN
Scripting syntax
About getting started with writing geoprocessing scripts
Union_arc (in_cover, union_cover, out_cover, fuzzy_tolerance, join_attributes)
in_cover (Required)
Coverage
union_cover (Required)
Coverage
out_cover (Required)
Coverage
fuzzy_tolerance (Optional)
Double
join_attributes (Optional)
Boolean
Script example
# SimpleUnion.py
# Description: Simple example of using Union in a python script
# Requirements: Python and the Python win32all extension
# Author: ESRI
# Date 1/1/2004
# Create the Geoprocessor
import arcgisscripting
gp = arcgisscripting.create()
# Put in error trapping in case an error occurs when running tool
try:
    # Union the parcels and counties to get the polys from both of these into one coverage
    gp.workspace = "c:/work/gisdata"
    gp.Union_arc("parcels", "counties","parcels2")
except:
    # If an error occurred print the message to the screen
    print gp.GetMessages()
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
