Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Coverage toolbox > Data Management toolset > Aggregate toolset > Tools
Append (Coverage) (ArcInfo only)
Release 9.3
Last modified December 29, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Tools"
Related Topics
NOTE: This tool only works with an ArcInfo license and will only be available in ArcToolbox if you have installed ArcInfo Workstation.
Combines an unlimited number of coverages into a single coverage.
Append checks for the existence of the coverage, verifies that the list of feature attribute table items matches the items in previously entered coverages (unless the FEATURES_ONLY option is used), and calculates Tic-ID and feature User-ID offsets according to the specified offset option.
Learn more about how Append works.
Illustration
Append illustration
Usage tips
Command line syntax
An overview of the Command Line window
Append_arc <in_covers;in_covers...> <out_cover> {FEATURES_ONLY | FEATURES_ATTRIBUTES} {POLY | LINE | POINT | NODE | NET | LINK | ANNO.subclass | SECTION.subclass | ROUTE.subclass | REGION.subclass} {NO | TICS_ONLY | FEATURES_ONLY | FEATURES_TICS}
Parameter Explanation Data Type
The Input Coverages to be appended. There is no limit to the number of coverages that can be entered.
Coverage; Coverage...
<out_cover>
The Output Coverage to be created. The Output Coverage cannot already exist.
Coverage
Determines whether only coordinates will be appended (FEATURES_ONLY) or whether features will also be appended.
  • FEATURES_ONLY — Location information for all feature classes that are appended. Feature attribute tables are not appended.
  • FEATURES_ATTRIBUTES — The features in the specified coverage define the set of features to be appended.
String
The feature class of the input coverage or coverages.
  • POLY — Polygon feature coordinates and attributes are appended including label points.
  • LINE — Arc feature coordinates and attributes are appended.
  • POINT — Point feature coordinates and attributes are appended.
  • NODE — Arc and node feature coordinates and their attributes are appended.
  • NET — Arc and polygon feature coordinates and their attributes are appended.
  • LINK — Arc and point feature coordinates and their attributes are appended.
  • ANNO.subclass — Annotation features and attributes of the subclass are appended.
  • SECTION.subclass — Section feature coordinates and attributes of the subclass are appended.
  • ROUTE.subclass — Route and section feature coordinates and attributes of the subclass are appended.
  • REGION.subclass — Region feature coordinates and attributes of the subclass are appended. Polygon feature coordinates and attributes are also appended.
The Add Value button, which is used only in ModelBuilder, allows you to add expected value(s) so you can complete the dialog box and continue to build your model.
String
Specifies how tics and coverage features will be numbered in the Output Coverage. IDs can be offset to ensure unique ID values for Output Coverage features. The ID offset is equal to 1 plus the highest ID value in the previously appended coverages. Offsets can be calculated for the following types of IDs:
  • NO — Neither Tic-IDs nor feature User-IDs will be modified. This is the default option.
  • TICS_ONLY — ID offsets will be calculated for tics.
  • FEATURES_ONLY — User-ID offsets will be calculated for the feature class(es) specified by the feature classes argument. Tic-IDs are not modified.
  • FEATURES_TICS — ID offsets will be calculated for both tics and features.
String
Data types for geoprocessing tool parameters
Command line example
append_arc "zone1; zone2; zone3; zone4" landuse FEATURES_ONLY POLY FEATURES_ONLY
Scripting syntax
About getting started with writing geoprocessing scripts
Append_arc (in_covers, out_cover, append_method, feature_classes, number_method)
in_covers (Required)
out_cover (Required)
Coverage
append_method (Optional)
String
feature_classes (Optional)
String
number_method (Optional)
String
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "c:/temp"
gp.toolbox = "arc"
gp.append("zone1; zone2; zone3; zone4", "landuse", "FEATURES_ONLY", "POLY", "FEATURES_ONLY")
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
