Show Navigation | Hide Navigation
You are here:
Geoprocessing tool reference > Environment Settings > General settings
M Tolerance
Release 9.3
Last modified December 17, 2008
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "General settings"
Related Topics
NOTE: This environment is only applicable to ArcGIS 9.2 or higher.
Specify the M tolerance that will be used for processing and set to the output geodataset.
Learn more about M tolerance.
Usage tips
Command line syntax
An overview of the command line window
MTolerance <Linear unit>
Parameters Explanation Data type
<Double> Tolerance value for adjusting m-values during cluster processing.
The default value is 10 * the M resolution.
Double
Data types for geoprocessing tool parameters
Command line example
MTolerance 0.02
Scripting syntax
An overview of scripting in geoprocessing
MTolerance (Linear unit)
Double (Required) Tolerance value for adjusting m-values during cluster processing. The default value is 10 * the M resolution. Double
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "h:/workspace"
gp.MTolerance = "0.02"
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
