You are here:
Geoprocessing tool reference
Environment Settings
General settings
NOTE: This environment is only applicable to ArcGIS 9.2 or higher.
Specify the Z resolution that will be used for processing and set to the output geodataset.
Learn more about Z resolution.
Usage tips
- If the output is a feature class inside a feature dataset, the environment will be ignored because all geodatasets inside a feature dataset must have the same Z resolution.
- If the output is a stand-alone feature class, raster catalog, or feature dataset, the tolerance of the input will be used as the processing and set as the output feature class' Z resolution. For tools that have multiple inputs (Intersect, for example), the resolution of the first geodataset in the list will be used as the default. To override these defaults, set the Z resolution environment to the desired value.
- If the geoprocessing tool does not have an input geodataset (for example, Create Feature Class, Create Feature Dataset, and Create Raster Catalog) and if the environment is left blank, the default Z resolution is set to 0.001 unit. To override this default, set the environment to the desired value.
Learn more about specifying general settings.
Learn more about environment settings.
Learn more about environment levels and hierarchy.
Command line syntax
An overview of the command line window
ZResolution <linear unit>
<Linear units> |
The resolution of Z values when creating feature classes.
The default value is the same as the XY resolution of 0.0001 meter or its equivalent in Z units. |
Linear Unit |
Data types for geoprocessing tool parameters
Command line example
ZResolution 0.002
Scripting syntax
An overview of scripting in geoprocessing
ZResolution (Linear unit)
Linear Unit (Required) |
Linear Unit |
Script example
import arcgisscripting
gp = arcgisscripting.create()
gp.workspace = "h:/workspace"
gp.ZResolution = "0.002"
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
