Understanding the network attribute |
Release 9.3
Last modified March 2, 2010 |
![]() ![]() ![]() Print all topics in : "Network dataset concepts" |
Network attributes are properties of the network elements that control their ability to traverse the network. Examples of attributes include the time to travel a given length of road, streets that are restricted for specific vehicles, the speeds traveled along a given road, and streets that are one-way.
Network attributes have five basic properties: name, usage type, units, data type, and use by default. Additionally, they have a set of assignments defining the values for the elements.
Certain attributes are used to measure and model impedances such as travel time (transit time on a street) or demand (the volume of garbage picked up on a street). These attributes are apportionable along an edge; that is, they are divided proportionately along the length of an edge. For example, if travel time is modeled as a cost attribute, then traversing half an edge will take half as much time as traversing the whole edge. This means that if the travel time to traverse the edge is 3 minutes, it takes 1.5 minutes to traverse half the edge. If you are looking for a 1.5-minute route along this edge, the route feature will be created from the first half of the edge feature.
Network analysis often involves the minimization of a cost (also known as impedance) during the calculation of a path (also known as finding the best route). Common examples include finding the fastest route (minimizing travel time) or the shortest route (minimizing distance). Travel time (drive time, pedestrian time) and distance (meters) are also cost attributes of the network dataset.
Descriptors are attributes that describe characteristics of the network or its elements. Unlike costs, descriptors are not apportioned. This means that the value does not depend on the length of the edge element. For example, the number of lanes is an example of a descriptor on a street network. Speed limit is another descriptor attribute for a street network. Although it is not a cost attribute and cannot be used as an impedance, it can be used in conjunction with distance to create a cost attribute (for example, drive time) that can be used as an impedance.
Restrictions can be identified for particular elements so that during an analysis, restricted elements cannot be traversed. For example, one-way streets can be modeled with a restriction attribute, so they can only be traversed from one end to another and not in the reverse direction. In all cases, a restriction attribute is defined using a Boolean data type.
In another example, certain sources where pedestrians are not allowed could be restricted using the attribute No_Pedestrians. In this case, the restriction can be used as a parameter during best route analysis to ensure the pedestrian does not use streets that are restricted.
Learn more about setting restrictions as parameters for route analysis.
Hierarchy is the order or grade assigned to network elements. A street network might have a road class hierarchy for separating interstates from local roads. In finding a shortest path from one point to another, the user preference to take or avoid interstates can be modeled through a hierarchy.
In ArcGIS Network Analyst, different classes of hierarchy can be grouped into three ranges: primary roads, secondary roads, and local roads. If your network has more than three classes of hierarchy, you can reclassify them into the supported ranges when you create your network dataset.
When you use a network that supports hierarchy for analysis, you can choose to create a route that uses hierarchy or you can create an exact route not using hierarchy. You can modify the hierarchy ranges at that point as well.
Learn more about performing a network analysis with hierarchy.
