Show Navigation | Hide Navigation
You are here:
Mapping and visualization > Page layout and map composition > Map output
Printing with the ArcPress printer engine
Release 9.3
Last modified April 24, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Map output"
Related Topics
About printing with the ArcPress printer engine
Note: This topic was updated for 9.3.1.
The ArcPress printer engine is designed to make printing large, complex maps possible on printers that may not have sufficient resources to process these maps. It can also help when printing maps that the Windows printer engine is unable to process. It does this by moving the processing of the map into a raster "picture" from the printer to your computer.
Using the ArcPress printer engine is a straightforward process. However, an understanding of the settings in ArcPress can help you attain your printing goals and avoid potential pitfalls.
Choosing the correct ArcPress driver for your printer
The ArcPress printer engine will automatically choose an ArcPress printer driver based on your printer model name when it is selected. ArcPress has specific drivers to support a variety of industry-standard printers. If ArcMap cannot match your printer type to an ArcPress driver, it will then prompt you to choose an ArcPress driver. However, the appropriate ArcPress driver for most large-format printers will be automatically selected.
If you are unsure about which driver to choose, check your printer manufacturer's documentation for raster language support. For example, printers from many companies support the HP RTL language, so you could choose an ArcPress HP RTL driver. Also, notice that a tip is displayed when you choose each driver from the ArcPress Properties dialog box, which will help you determine which driver is correct for your printer:
For more information on printers and drivers, see the knowledge base article #32745 FAQ: Which printers are supported by ArcGIS Desktop 9.x?
Output resolution
Resolution (measured in dots per inch, or dpi) is the size of the dot that is used to make up a print job. The print processing time and the time it takes to print will generally be longer when you select a higher value.
Increasing the resolution does not always ensure a higher-quality print, because the printed image might become too saturated, or the difference between the lower- and higher-dpi prints might not be varied enough to justify the longer processing time.
The ratio listed in the Output Image Quality control determines the effective resolution of raster content on output relative to the printer's selected resolution.
For the HP Universal and Epson Universal drivers, the resolution can be set individually for the rasterizer and output to the printer. These options can be changed by using the print quality options that best suit your print job's purpose and content. See the Additional settings for universal drivers section for more information regarding these options.
For the RTL and PCL drivers, the dialog box will automatically show output resolutions that are supported by your printer according to the installed printer driver.
About changing color parameters
While in most cases ArcPress should provide good color on the first print, you can use the ArcPress Color Adjustment options to alter the appearance of your map output. If the map document is saved with the Use Printer Paper Settings option (on the Page and Print Setup dialog box) checked, these settings will be saved with the map document. Note that these color parameters affect the entire map, both raster and vector information.
The ArcPress Color Adjustment dialog.
The ArcPress Color Adjustment dialog box has sliders for commonly used color correction parameters.
The HP Universal and Epson Universal drivers have additional settings.
How to print with ArcPress
Choosing the ArcPress printer engine
  1. Click the File menu and click Print.
  2. Click the Printer Engine drop-down arrow and click ArcPress Printer.
  3. Print engine selection menu.
    The Printer Engine selection menu
  4. Optionally, click the Properties button and modify any additional options such as the ArcPress printer engine selected. Click OK to apply these changes.
  5. Click OK to Print, or click Close to save your changes and close the Print dialog box.
Tip
  • In some cases, ArcMap may prompt you to choose an ArcPress driver. Choose the one that best matches your printer. If you are not prompted to choose a driver, then ArcMap has chosen one for you based on the printer name. You should verify that the correct ArcPress driver and driver properties have been selected when you print.
Choosing the appropriate ArcPress driver
  2. Choose ArcPress Printer in the Printer Engine drop-down list.
  3. Print Engine selector.
    The Printer Engine selector menu
  4. Normally an ArcPress driver will be chosen for you. If you want to pick a different driver, click the Properties button. If a driver cannot be found for your printer's model name, the ArcPress Printer dialog box will appear automatically.
  5. On the ArcPress Printer dialog box, click the Driver drop-down arrow and click the ArcPress driver that best matches your printer.
  6. ArcPress Properties dialog.
    The ArcPress Printer dialog box. Note the Driver selection drop-down list.
  7. Modify any additional options such as the Print as Black and White option. Click OK to apply the changes or cancel to dismiss the ArcPress Printer dialog box.
  8. Click OK on the Print dialog box to print, or click Close to save your changes and close the Print dialog box.
Tips
  • ArcPress will automatically try to select the printer driver that is the best match for your printer. Most users will not need to select a driver manually.
  • If you are unsure about which ArcPress driver to choose, consult your printer manufacturer's documentation.
  • Checking the Print as Black And White check box creates a black and white print for all drivers except the RTL (RGB) TrueColor driver. Use this option for monochrome printers or when you want to create a black and white print on a color printer.
Setting the output resolution
  2. Make sure you have chosen the ArcPress Printer engine in the Printer Engine drop-down list. Click Properties.
  3. For the RTL and PCL drivers, click the Resolution drop-down arrow and click the output resolution (dpi) that best suits your printer and output requirements. If the value you need does not appear, you can type the dpi you want to use.
  4. For the HP Universal and Epson Universal drivers, change the print quality options to match your output requirements.
  5. Optionally, make any other necessary modifications. Click OK.
  6. Click OK on the Print dialog box to print, or click Close to save your changes and close the Print dialog box.
Setting the output image quality
  2. Move the Output Image Quality slider to the desired setting or type a value (for example, 1:5 for Fast quality) in the Ratio text box.
  3. Output Image Quality slider.
    The Output Image Quality slider, along with graphic preview
  4. Optionally, click the Properties button and modify any additional options. Click OK.
  5. Click OK on the Print dialog box to print, or click Close to save your changes and close the Print dialog box.
Tips
  • By default, the output image quality ratio will be set to 1:3 or Normal. It is recommended that you use this setting or change it to 1:2 (Normal Best) unless the print job cannot be processed at this quality.
  • The ratio listed in this dialog box determines the effective resolution of raster content on output. For instance, if the output image quality is set to 1:2 and the output resolution is set to 300 dpi, the raster content will be output at approximately 150 dpi.
Saving paper when printing
  2. Click the Printer Engine drop-down arrow, select ArcPress Printer, then click Properties.
  3. If your map can be reoriented on the page to reduce paper usage, check the Save Paper check box. This will automatically rotate the map on the printer paper. This is useful in situations where the length of the longest side of a map is shorter than the width of the paper that is currently loaded.
  4. Modify any additional options. Click OK.
Tip
    If your printer can print wider than 36 inches, you will need to be careful when using the Save Paper command. Some manufacturers' printer drivers do not store the installed printer paper width correctly. Using this option may cause your map to rotate off the actual printer paper and print clipped.
Adjusting the color
  2. Click the Properties button.
  3. On the ArcPress Properties dialog box, click the Color Adjustment button.
  4. On the Color Adjustment dialog box, move the Gamma, Brightness, Contrast, and Saturation sliders to adjust the color.
  5. ArcPress Color Adjustment dialog.
  6. Click OK to apply the color changes.
  7. Click OK on the Print dialog box to print, or click Close to save your changes and close the Print dialog box.
Choosing the media type (HP Universal and Epson Universal only)
  2. Click Properties.
  3. On the ArcPress Properties dialog box, under Media Type, choose the appropriate type of media loaded into your printer or the closest match.
  4. Optionally, modify any additional options. Click OK.
Tips
  • Choosing a media type that does not match the media loaded into the printer will generally result in poor-quality output, over- or underinking, or other printing anomalies. Always choose the appropriate media type.
  • Some manufacturers may change the name of their paper stocks from time to time. Contact your printer or paper vendor to determine the appropriate media type to use with a given paper type.
Choosing the ink type (Epson Universal driver only)
  3. On the ArcPress Properties dialog box, under Ink Type, choose the appropriate type of ink loaded in your printer.
Tip
    Choosing an ink type that does not match the ink loaded in the printer can result in errors at the printer. Be sure to choose the correct ink type according to what is currently loaded in the printer.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
