You are here:
Mapping and visualization
Working with graphs and reports
Creating reports
About saving and loading a report
This topic was updated for 9.3.1.
If you want to copy a report from one map to another, save it to a file on disk. You can then load the report in another map and place it as appropriate. When you save a report to a file, you're creating a static copy that is not linked to the actual data from which you created the report. Thus, you won't be able to modify the report in any way.
You can also export a report to the following file types:
- Adobe Portable Document Format (PDF)
- Rich Text Format (RTF)
- Plain text (TXT)
How to save and load a report
Saving a report
- Click Save on the Report Properties dialog box.
- Click the Save in drop-down arrow and navigate to the location where you want to save the report.
- Type a name for the report.
- Click Save.
Loading a report
- Click Load in the Report Properties dialog box.
- Click the Look in drop-down arrow and navigate to the location where the report is stored.
- Click the report.
- Click Open.
Exporting a report
- Click Generate Report on the Report Properties dialog box.
- Open the Report Viewer window and click Export.
- Click the Save in drop-down arrow and navigate to the location where you want to save the exported report.
- Click the Save as type drop-down arrow and click the type of file you want to export.
- Click Save.
Once you create your report, you can include it on your map and export it to several different file formats: Adobe PDF, RTF, or plain text.
Please visit the
Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
