Show Navigation | Hide Navigation
You are here:
Extensions > Spatial Analyst > Spatial Analyst functional reference > Neighborhood (Spatial Analyst)
Focal Statistics
Release 9.3
Last modified September 7, 2011
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Neighborhood (Spatial Analyst)"
Related Topics
Calculates a statistic on a raster over a specified neighborhood.
Learn more about how Focal Statistics works
Usage tips
Command line syntax
An overview of the Command Line window
FocalStatistics_sa <in_raster> <out_raster> {neighborhood} {MEAN | MAJORITY | MAXIMUM | MEDIAN | MINIMUM | MINORITY | RANGE | STD | SUM | VARIETY} {DATA | NODATA}
Parameter Explanation Data Type
<in_raster>
The raster to perform the Focal Statistics calculations on.
Composite Geodataset
<out_raster>
The raster to be created.
Raster Dataset
{neighborhood}
Dictates the shape of the area around each cell used to calculate the statistic.
  • ANNULUS, {inner_radius}, {outer_radius}, {CELL | MAP}  — A torus (donut-shaped) neighborhood defined by an {inner_radius} and an {outer_radius}.
  • CIRCLE, {radius}, {CELL | MAP}  — A circular neighborhood with the given {radius}. The default is three cells.
  • RECTANGLE, {width}, {height}, {CELL | MAP}  — A rectangular neighborhood with the given {height} and {width}. The default rectangle is a square of width 3 and height 3, in units of cells. If only one of {width} or {height} is specified, the result is a square.
  • WEDGE, {radius}, {start_angle}, {end_angle}, {CELL | MAP}  — A wedge-shaped neighborhood. A wedge is specified by a {start_angle}, an {end_angle}, and a {radius}. The wedge extends counterclockwise from the starting angle to the ending angle. Angles are specified in degrees, with 0 or 360 representing east. Negative angles may be used.
  • IRREGULAR, kernel_file  — A custom neighborhood with specifications set by a user-defined file.
  • WEIGHT, kernel_file  — A custom neighborhood defined with an user-defined file, which can apply weights to the members of the neighborhood.
  • {CELL | MAP}  — Defines the units as either {CELL} or {MAP}.
The default neighborhood is a square RECTANGLE with a width and height of three cells.
Neighborhood
The statistic type to be calculated.
  • MEAN  — Calculates the mean (average value) of the cells in the neighborhood.
  • MAJORITY  — Calculates the majority (value that occurs most often) of the cells in the neighborhood.
  • MAXIMUM  — Calculates the maximum (largest value) of the cells in the neighborhood.
  • MEDIAN  — Calculates the median value of the cells in the neighborhood.
  • MINIMUM  — Calculates the minimum (smallest value) of the cells in the neighborhood.
  • MINORITY  — Calculates the minority (value that occurs least often) of the cells in the neighborhood.
  • RANGE  — Calculates the range (difference between largest and smallest value) of the cells in the neighborhood.
  • STD  — Calculates the standard deviation of the cells in the neighborhood.
  • SUM  — Calculates the sum (total of all values) of the cells in the neighborhood.
  • VARIETY  — Calculates the variety (the number of unique values) of the cells in the neighborhood.
The default statistic type is Mean.
String
{DATA | NODATA}
Denotes whether NoData values are ignored by the statistic calculation.
  • DATA  — Specifies that if a NoData value exists within a neighborhood, the NoData value will be ignored. Only cells within the neighborhood that have data values will be used in determining the output value.
  • NODATA  — Specifies that if any cell in a neighborhood has a value of NoData, the output for each cell in the corresponding block will receive NoData. Whenever the NoData keyword is used, the presence of a NoData value implies that there is insufficient information to determine the statistic value for the neighborhood.
Boolean
Data types for geoprocessing tool parameters
Command line example
FocalStatistics_sa C:/data/raster1 C:/data/focalstat "Rectangle 5 6 Map" DATA
Scripting syntax
About getting started with writing geoprocessing scripts
FocalStatistics_sa (in_raster, out_raster, neighborhood, statistics_type, ignore_nodata)
in_raster (Required)
out_raster (Required)
Raster Dataset
neighborhood (Optional)
Neighborhood
statistics_type (Optional)
String
ignore_nodata (Optional)
Boolean
Script example
# FocalStatistics_sample.py
# Description:
#   Calculates a statistic on a raster over a specified neighborhood.
# Requirements: None
# Author: ESRI
# Date: Sept 6, 2005
# Import system modules
import arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create()
try:
    # Set local variables
    InRaster = "C:/data/raster1"
    OutRaster = "C:/data/focalstat"
    InNeighborhood = "Rectangle 5 6 Map"
    InNoDataOption = "DATA"
    # Check out Spatial Analyst extension license
    gp.CheckOutExtension("Spatial")
    # Process: FocalStatistics
    gp.FocalStatistics_sa(InRaster, OutRaster, InNeighborhood, "", InNoDataOption)
except:
    # If an error occurred while running a tool, then print the messages.
    print gp.GetMessages()
Map Algebra syntax
See FocalMajority, FocalMax, FocalMean, FocalMedian, FocalMin, FocalMinority, FocalRange, FocalStd, FocalSum, FocalVariety, depending on the desired Focal statistic.
ArcObjects syntax
INeighborhoodOp::FocalStatistics (geoDataset As IGeoDataset, type As esriGeoAnalysisStatisticsEnum, nbrhood As IRasterNeighborhood, ignoreNoData As Boolean) As IGeoDataset
geoDataset An input Raster, RasterDataset, RasterBand, or RasterDescriptor that identifies the values of the focal or processing cell and the values of the cells in its specified neighborhood.
type An esriGeoAnalysisStatisticsEnum defining the focal statistic to calculate within each neighborhood.
The enumeration types are:
  • esriGeoAnalysisStatsMajority  — Majority
  • esriGeoAnalysisStatsMaximum  — Maximum
  • esriGeoAnalysisStatsMean  — Mean
  • esriGeoAnalysisStatsMedian  — Median
  • esriGeoAnalysisStatsMinimum  — Minimum
  • esriGeoAnalysisStatsMinority  — Minority
  • esriGeoAnalysisStatsRange  — Range
  • esriGeoAnalysisStatsStd  — Standard Deviation
  • esriGeoAnalysisStatsSum  — Sum
  • esriGeoAnalysisStatsVariety  — Variety
nbrhood A RasterNeighborhood defining the configuration of the neighborhoods within which the focal statistics will be calculated.
INeighborhoodOp::FocalStatistics supports any neighborhood supported by RasterNeighborhood, such as rectangle, circle, annulus, wedge, and an irregularly-shaped neighborhood. The neighborhood will be defined by the minimum-bounding rectangle of the specified neighborhood. The minimum-bounding rectangle will include more cells than the specified neighborhood in certain cases, such as with a circle, annulus, and wedge.
ignoreNoData A Boolean defining the manner in which NoData values within a neighborhood will influence the output results.
If True, and if a NoData value exists within the neighborhood of the processing cell, the NoData value will be ignored. Only cells within the neighborhood that have data values will be used in determining the statistic.
If False, and if any cell in a neighborhood has a value of NoData, the output for the processing cell of the neighborhood will be NoData. When False, the presence of a NoData value implies that there is insufficient information to determine the statistic of the values of the neighborhood.
ArcObjects example
' Create the RasterNeighborhoodOp object
Dim pNbrOp As INeighborhoodOp
Set pNbrOp = New RasterNeighborhoodOp
' Create the neighborhood object
Dim pNbr As IRasterNeighborhood
Set pNbr = New RasterNeighborhood
pNbr.SetCircle 3, esriUnitsCells
' Call a function to open a raster dataset
Dim pInputDataset As IGeoDataset
Set pInputDataset = OpenRasterDataset ("D:\SpatialData\", "inputraster")
' Create output using the method
Dim pOutputRaster As IRaster
Set pOutputRaster = pNbrOp.FocalStatistics(pInputDataset, _
                      esriGeoAnalysisStatsMajority, pNbr, False)
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
