Show Navigation | Hide Navigation
You are here:
Tables and attribute information > Displaying tables and attribute information
Setting field properties, aliases, and table display options
Release 9.3
Last modified April 24, 2009
E-mail This Topic Printable Version Give Us Feedback
Print all topics in : "Displaying tables and attribute information"
Related Topics
About setting field properties and aliases
Note: This topic was updated for 9.3.1.
There are table and layer properties that allow you to customize which data can be displayed and how it will be formatted. For example, you may
These properties are set in several different places including the Layer or Table Properties dialog boxes, the table window, and the Tools > Options dialog box. However, there are some field properties that you cannot change. These include field type, length, precision, and scale.
When you are editing features, the customizations made for the display of attribute data will not be shown in the Attributes dialog box (displayed from the Editor toolbar) because the Attributes dialog box is designed to show the exact setup of the database rather than the user-friendly view you may prefer in your maps.
The primary display field
The primary display field is the most useful and unique field of an attribute table or table. For example, the primary display field for a countries layer would be its Name field or the parcel number for a parcels layer.
The primary display field defaults to the first field of string type that contains the text "name" (case insensitive) in the field name. If no "name" field exists, the primary display field defaults to the first field of string type, then the first field of integer type, then the first field of any type. You can change the primary display field from the Fields tab of the Layer or Table Properties dialog box.
The content of a layer's primary display field is used
If you are working with a table that has no associated features, the primary display field will be used
Field aliases
An alias is an alternative name for a field: a more user-friendly description of the content of the field. Unlike true names, aliases do not have to adhere to the limitations of the database, so they can contain special characters such as spaces. By specifying an alias, you can give names to fields that are more descriptive than their actual field name. For example, you might specify an alias of "Date of deed" for a field stored in the geodatabase as "DEED_DATE".
Once you create a field, you cannot rename it. You can, however, specify an alias (or you could create a new field with the name you want and delete the old field).
There are two types of field aliases: feature class field aliases (geodatabase only) and layer field aliases. You work with feature class field aliases in ArcCatalog on the Feature Class Properties dialog box. When a geodatabase feature class is added to ArcMap, its field aliases are used initially for the layer field aliases. However, after this, there is no link between the two. Properties set in ArcMap will override the properties of the data source, but they will not be carried back to the data source. This means that if you change a layer field alias, it will not change the feature class field alias, and if you change a geodatabase field alias, it will not update the layer field alias for any existing layers based on the feature class.
You can only maintain what you set on the Fields tab by saving the map document or the layer to a .lyr file.
Table display options
When you open a table, you can customize its appearance in a variety of ways. For example, if you don't like the default table font, you can change it and set the font size as well. You can make changes for all tables or just one—each table can have its own individual settings.
When examining an individual table's contents, you can resize columns to better see their values. You can also reposition them to compare the values in one field to the values in another. Freezing a table's columns can be helpful when you're exploring its contents. Frozen columns are locked in position at the left of the table and are separated from the other columns by a heavy black line. When scrolling horizontally, all other columns move normally, but the frozen columns remain fixed.
Some of the display options you can set include
It's easy to work with table windows when you make them small to fit on your screen. If the Options menu button is hidden due to the width of the table window, a small control appears at the bottom right hand corner of the window. You can click this control to access the Options menu. You can also right-click any of the empty gray space at the bottom of the table to access the Options menu.
The button in the bottom right corner opens the Options menu
Setting column header and cell heights
You can change the heights of the column headers (the row along the top of the table window that shows you the names of the fields) and cells. By increasing these values, you can increase the height of the rows.
If the value you specify for the column header or cell height provides enough space to accommodate additional lines, the field name inside the column header or the content in the cell will wrap if it exceeds the current width of the column. This is particularly useful if your table contains long field names or long text fields such as description or comment fields. Increasing the header or cell height in your table can make these fields easier to read.
Text wrapping in the cells
The default height of a header is 125% of the font size. The default cell height is 115% of the font size. If you set the cell height value to be below 115%, it can prevent the insertion bar appearing when you try to edit the contents of cells.
You should normally leave the default header height at 125% and the default cell height at 115% in the Tables tab of the Tools menu > Options dialog box, so all the new tables you create use this standard setting. If you want a particular table to have taller rows so long text fields wrap around as shown above, specify the setting through the table window's Options > Appearance dialog box. In this way, the setting will just apply to that particular table.
Quickly setting field properties and aliases
With the table window open, you can right-click a field heading and click Properties to open a dialog box that allows you to set and view certain properties of that field. This dialog box lets you specify a field alias; turn the field on or off; make that field the primary display field; change its number format if it is not a string field; and review (but not change) the field's other data properties, such as whether it allows null values, and its precision and scale.
Setting column widths
In the table window, fields are shown in columns. You can drag the column dividers between fields left and right to change their width including dragging dividers so that fields are completely hidden.
You can also automatically reset the column widths to undo changes you made. The Restore Default Column Widths command in the Options menu resets all the columns to their default widths. This also reveals any fields that are completely hidden because their column has been dragged to have no width. The Restore Default Column Widths command doesn't reset the field order, so if you have dragged and dropped fields around in the table window, this reordering is preserved when you use the command.
If a field has been completely hidden in the table, you'll see a thicker column divider at that position. This makes it easy to see where one or more fields have been hidden. If several fields have been hidden at that position, you'll see an even thicker divider.
Table window with a hidden field
To unhide a hidden field, drag the thick divider to the right, or double-click on the divider. To reveal all hidden fields, use the Restore Default Column Widths command in the Options menu. Completely hiding fields in the table window is useful because it lets you choose how you want the table to appear, including how it appears when you use the new Print command in the Options menu to print the table, without turning fields off completely, which would prevent them being listed elsewhere.
How to set field properties and aliases
Setting the primary display field
  1. If the field is in a layer's attribute table, right-click the layer in the table of contents and click Properties.
  2. If the field is in a table without features, click the Source tab in the table of contents, right-click the layer in the table, then click Properties.
  3. Click the Fields tab in the Properties dialog box.
  4. Click the Primary display field drop-down arrow and click a field.
  5. Click OK.
Tip
  • A setting in the Table Appearance dialog box launched from the Options button in the table window lets you choose to indicate the primary display field in the table window by adding a special character after its name. If you want to be able to see which field is being used as the primary display field, turn this option on and choose the character you'd like to use (the default is a pound sign #). By default, this option is turned off. If you want this option to be turned on by default for all the new table windows you open, turn it on in the Tables tab of the Tools > Options dialog box. Settings you turn on in that dialog box don't apply to tables you have already opened in your existing map, globe, and scene documents.
Setting whether fields are visible
  1. Open the table.
  2. Right-click the field heading and click Turn Field Off.
Tips
  • You can open the Layer Properties or Table Properties dialog boxes and use the Fields tab to set field visibility.
  • To toggle visibility for all fields from the Fields tab, hold down the Ctrl key when you click the check box next to any field, or press Ctrl + Spacebar if a field is currently selected (highlighted) in the list.
  • Another quick way of turning off a field from the table window is to hold down the Ctrl key and double-click the field heading. To turn all the fields on again, choose the Turn All Fields On command in the table window's Options menu.
  • This is the same as going to the Layer Properties dialog box > Fields tab and choosing Select All. All the fields in the data source will be turned on. This command is disabled if none of the fields are currently turned off.
Setting field aliases
  1. Open the table.
  2. Right-click a field heading and click Properties.
  3. Type an alias.
  4. Click OK.
Tips
  • You can open the Layer Properties or Table Properties dialog boxes and use the Fields tab to set aliases.
  • Ctrl + right-click a field name or use Ctrl + Shift + N to switch between showing field names and field aliases in a table. You can also toggle by clicking the table Options menu and clicking Show Field Aliases.
Formatting numeric fields
  1. Open the table.
  3. Click the Number Format ellipsis button Number format button.
  4. Set the category and options you want to use in the Number Format dialog box.
  5. Each number format category has its own set of available formatting options. For example, with the Numeric category, you can specify the number of decimal places or significant digits to display and the alignment of the cell and turn on or off options for showing thousands separators, padding with zeros, and a plus sign for positive numbers.
  6. Click OK on all dialog boxes.
Tips
  • Changing how attribute data is displayed does not change the underlying data. The formatting information is only saved in the layer or map you are editing.
  • You can open the Layer Properties or Table Properties dialog boxes and use the Fields tab to format numeric fields. If you are using the keyboard to navigate around the list of fields on the Fields tab, you can press the Spacebar to activate the Number Format button once you have used the arrow keys to get over into the Number Format column.
  • If you find that numeric values are being cut off or rounded in the table, right-click the field, click Properties, and review the number formatting. Since six is the default number of decimal places to display in the table window, you may need to increase this value to see the full number. For example, if you have a table in an ArcSDE geodatabase containing a field of type double with a scale of eight, the last two digits are dropped off because the table window only displays six decimal places by default. Increasing the number of decimal places will allow you to see all the digits. Similarly, you can decrease the number of decimal places if you want to see fewer in the table window.
Setting the selection and highlight color for tables
  1. To set the default selection and highlight color for all tables, click the Tools menu, click Options, and click the Tables tab.
  2. To set the selection and highlight color for an individual table, click Options on the table window and click Appearance.
  3. Click the Selection Color drop-down arrow and click the color you want to use.
  4. Click the Highlight Color drop-down arrow and click the color you want to use.
  5. Click OK.
Tips
  • Settings applied to the Options dialog box accessed from the Tools menu will apply to all tables you work with in all ArcGIS Desktop applications. Changing this setting here changes it for all the applications. Changing this setting here applies to new table windows you open, not to table windows you have already opened. To change the setting for a table window you have already opened, choose the Appearance command in the Options menu in that table window.
  • Settings applied from the Appearance command in the Options menu on a table window will apply to the current table you are working with.
Setting other table display options
  1. For the default settings for all tables, click the Tools menu, click Options, and click the Tables tab.
  2. For an individual table, click Options on the table window and click Appearance.
  3. To set the text font and size, click the Table Font drop-down arrow and click the font you want to use. Click the Table Font Size drop-down arrow and click a point size.
  4. To set the column header height at the top of the table and the height of rows in the table, type values for the percentage of font size.
  5. To set the character used when indicating whether a column has an index associated with it, type the character. Uncheck Mark indexed fields with if you prefer not to see which columns are indexed.
  6. To set the character used when indicating the primary display field, type the character. Uncheck Mark primary display field with if you prefer not to see which column is the primary display field.
  7. To set subtype and domain options, check Display coded value domain and subtype descriptions and check the box to validate records automatically.
  8. Click OK.
Tips
  • You should normally leave the default column header height at 125% and the default cell height at 115% in the Tables tab of the Tools menu > Options dialog box, so all the new tables you create use this standard setting. If you want a particular table to have taller rows so long text fields wrap, specify the setting through the table window's Options > Appearance dialog box. In this way, the setting will just apply to that particular table.
  • If the height you specify for the Cell Height provides enough space in a cell to accommodate additional lines, the content of the cell will wrap if it exceeds the current width of the column. This is particularly useful if your table contains long text fields such as description or comment fields. Increasing the height of the cells in your table makes these fields easy to read.
  • The coded value domain and subtype descriptions are for display purposes only. When working with the data, such as calculating, querying, or finding values, make sure to use the actual values. This setting only applies to data from geodatabases where domains and subtypes have been defined.
  • This and the automatic validation settings don't apply to the Attributes window, which is opened from the Attributes button on the Editor toolbar.
Changing a column's width
  1. Position the mouse pointer to the edge of the column you want to resize.
  2. The pointer's icon changes.
  3. Click and drag the column's edge to the desired width.
  4. A black line indicates where the edge of the column will be located.
  5. Drop the edge of the column.
  6. The column is resized.
Tip
  • The Restore Default Column Widths command in the table window Options menu resets all the columns to their default widths. This also reveals any fields that are completely hidden because their column has been dragged to have no width.
Rearranging a table's columns
  1. Click the heading of the column you want to move.
  2. Click and drag the column's heading.
  3. A red line indicates where the column will be positioned.
  4. Drop the column.
  5. After you drop it, the column appears in the new position.
Freezing a column
  1. Click the heading of the column you want to freeze.
  2. Right-click the selected column's heading and click Freeze/Unfreeze Column.
  3. The column is now frozen.
Tips
  • Right-click the column heading and click Freeze/Unfreeze Column to unfreeze the column.
  • To hide a column, right-click the layer or table in the table of contents, click Properties, then click the Fields tab. You can then set whether or not a field is visible.
Please visit the Feedback page to comment or give suggestions on ArcGIS Desktop Help.
Copyright © Environmental Systems Research Institute, Inc.
