Use a text editor to edit the MyCoordSysDefs.fme file in your Reproject directory. This directory is located where FME was installed on your system. (You might want to create a backup copy of the file before you make any changes.)
The projection and units of your source data are not predefined within FME, so, to define them, you must edit the mapping file to add the following lines:
Coordinate System Definition Lines |
Additional Information |
COORDINATE_SYSTEM_DEF <coordsysname> |
PROJ <projType> |
Table of projection types |
UNIT <unitName> |
Table of predefined units |
(DT_NAME <datumName> | EL_NAME <ellipName>) |
Table of predefined datums and predefined ellipsoids. Note that each coordinate system definition must specify either a datum or ellipsoid. |
[<parameter> <value>]+ |
[DESC_NM <descriptive_name>] |
[GROUP <group_name>] |
Tip: Defining a unique group name allows you to sort coordinate systems by the "Group" column in the Coordinate System Gallery. |
[QUAD <quadrant>] |
Quadrant definition |
[SOURCE <source>] |
For example, this mapping file fragment defines a NAD83 based UTM Zone 12 coordinate system.
COORDINATE_SYSTEM_DEF UTM12N83 \ |
PROJ TM \ |
UNIT METER \ |
DT_NAME NAD83 \ |
PARM1 -111.0 \ |
GROUP "Custom Group" \ |
SCL_RED 0.9996 \ |
ORG_LAT 0.0 \ |
X_OFF 500000.0 \ |
Y_OFF 0.0 \ |
MAP_SCL 1.0 \ |
ZERO_X 0.001 \ |
ZERO_Y 0.001 |
After you have edited, saved, and closed the MyCoordSysDefs.fme file, FME will automatically recognize your custom coordinate system, and it will appear in the columns of the Coordinate System Gallery. These columns are, in order, Name, Description, Group, Datum, Ellipsoid, Projection, and Units.
Notes:
When you update to a newer version of FME, the MyCoordSysDefs.fme file will not be overwritten. (However, it is always good practice to back up any custom files.)
The parameters above are described in Local Coordinate Systems
For a complete list of generic parameters that you can define, please see Generic Parameters.
If you are working with custom mapping files and you set coordinate system definitions, you will have to remove the definitions after they are defined in the MyCoordSysDefs.fme file – the same coordinate system cannot be defined in both places.
See also Sharing Custom Coordinate Systems.
