By default, Workbench stores Transformers in default categories. However, you can customize the gallery to suit your workflow purposes.
You can create custom folders in the Transformer Gallery, and drag transformers in and out of folders.
Collapse the folders in the Transformer Gallery, and right-click in the blank area below the folders. Click the New Folder menu that appears:
Type a folder name in the dialog and the new folder will appear in the Gallery. You can drag any transformer in the Gallery to the new folder.
Right-click on the custom folder:
Export... sends the list of transformer it contains to a file (for example, Favorites.fmxlist).
Send To... opens your default e-mail client and attaches the list to a new e-mail.
An .fmxlist file is a text file that contains a list of transformers, which you can easily install into the Transformer Gallery.
Note that you will have to restart Workbench following this installation.
To install the new folder into your Transformer Gallery, you can either drag an .fmxlist file onto the Transformer Gallery window, or double click the file. Note that if you already have a folder with the name specified in the file, you will be prompted to overwrite the name, install it under a new name, or cancel the operation.
You will see this message:
When you click Yes, the list will be installed. Restart Workbench to see the list in the Transformer Gallery.
