The FME Administrator extends any of your "FME-ready" third-party applications.
Find your FME folder in the Windows Start menu, and choose FME Administrator:
If your machine contains any installed applications that can be extended to support FME, they will be listed in this window, along with their current state.
The Current State lists the build number that extends the application. This <build number> will change each time you update FME.
To extend the application, click the Extend button. To revert the application to a Not Extended state, click the Revert button.
To see details about an application (in either state), including minimum build numbers required, click Details.
