Select Tools > Options and click the Runtime icon.
Sets the CPU priority for running translations. In most cases, the default normal setting will be adequate. If you regularly run large translations, you can keep the default setting, or change it to low, so the translations won't dominate your CPU (and so you can do other work in the foreground while the translation is running). If you have other CPU-intensive tasks running concurrently, you may want to set the priority to high to make sure the translation gets its share of the CPU.
If you check this box, FME will transmit information about your version of Windows and how you use FME. The information collection process is completely anonymous, and your results will be automatically combined with other users' results. The resulting statistics will help us identify trends and usage patterns (for example, which formats and processing facilities are utilized more than others), which in turn will help us focus our development efforts for future versions of FME. We will not collect your name, address or any other personally identifiable information.
Save log file: Save the translation log in the default workspace directory. (When you choose "Save to file" in the log pane, the default location will be the location you choose under Default Workspace Directory, below. The default filename will be translation_log.txt.)
Append to log file: Appends log results to the previously generated log, instead of overwriting the file.
