You can reorder datasets in a workspace if you want one dataset to be read or written before another. Select a dataset and click the right mouse button to display the command menu. Then select Move Up in List or Move Down in List.
If you want to temporarily disable a dataset, select Disable Dataset.
To remove a dataset, simply select it in the Navigator and choose Delete Dataset from the command menu. You can also choose Remove Dataset from either the Source Data or Destination Data menus.
