Once a workspace becomes a complex series of parallel streams it’s important that you are able to test each stream separately, and also be aware of how changing one component can impact other sections further on in the workflow.
If you see an Incomplete Transformers
node in the Navigator, it means that the workspace contains one or more
transformers that need parameters filled in before the transformer will
be operational. Any transformer that has a red properties button with
an exclamation point
will appear in the list. (Transformers
with a yellow properties button will not appear in this list, since they
will not prevent the workspace from running.)
The Navigator displays an Incomplete Transformers node, and the problem parameter is shown in red. Most times, you will just need to enter or set a value, the parameter icon will change to green, and the transformer will be removed from the "Incomplete" list.
Occasionally, this situation can arise when changes to one transformer cause the settings in another to become invalid.
FME will automatically flag transformers when they are adversely affected by changes elsewhere. It does this by resetting the transformer properties button back to red, to indicate that attention is required.
The individual setting that is causing the problem is also separately highlighted. FME takes changes into consideration for the entire workspace, not just the changed transformer.
