Basic Workspace Settings are displayed in the left-hand navigator pane:
Double-click to add or edit the workspace name and/or location. When you click OK, the changes will reflect in the Workbench title bar.
This setting allows you to enter a description of what the workspace does. Where this setting is particularly important is when you are using the workspace via an FME Server – because it provides a mechanism for a web page to describe what the process is intended to carry out.
Double click this parameter to display the settings. When you click the Browse button, a command-line window will appear. Type the description for your workspace. For example:
Then click the OK button at the bottom to dismiss the window.
The description you enter will appear in the Workspace Description with the proper character encodings for spaces, etc.
The log file parameter points to the location where a log file will be created when the workspace translation is executed.
See Redirecting the Source and Destination.
See the topics under Advanced Settings.
