| Configuration Add-Ins |
Feedback
E-mail this topic
Print this topic
Any add-in files that contain the add-ins that you reference when customizing ArcGIS Explorer with your application configuration are listed in the Add-ins page. You can add additional add-in files or remove those that are no longer referenced. To verify whether a file's add-ins are referenced by the configuration's customizations, select the file and click Properties... to get a list of the add-ins and which are used in the Customize tab on the Ribbon.
If you have a newer version of an add-in file you can replace it by re-adding it to the configuration.
