| Set Note Properties |
Feedback
E-mail this topic
Print this topic
You can use the Note Properties dialog to set or change two properties of the note.
If you've established a note's view, when you double-click the note in the Contents window or right-click the note and select Go To the map will move to display the default view.
The default view will be a target location and an observer location if you create or capture it in 3D display mode. If you capture the default view in 2D display mode, then it consists of an extent and a rotation value.
The note's location is independent of the view. While improbable, it is possible to position the note outside the extent of the view.
Learn more about working with Notes
