| Recapture a slide |
Feedback
E-mail this topic
Print this topic
During the course of creating a presentation, you'll find that you may need to make modifications to a slide so that it reflects the current state of the map. You can, of course capture a new slide and delete the old one, but there may be instances in which one part of your slide requires a change, for example, the slide title, but everything else, the viewpoint, the visible map content, etc. should remain the same. You can make the necessary changes to your slide and then on the Presentation tab, in the Slides group, click Recapture Slide:
This action captures the current state of the map and replaces the selected slide, in the same position as the original slide in the slide set.
