Choosing the look and feel of the application |
| Release 9.3.1 |
After choosing layers and tasks, you'll set the supporting details for the application such as title, links, and which map elements to display.
Two panels of Manager assist you in configuring the look and feel of your application. The first allows you to set the page properties, namely the title text, theme, and links to external Web sites. The second panel includes a list of map elements that you can enable and configure for the application.
You can access these panels while either creating a new Web application or editing an existing application in Manager.
Tip: For further information about how you can configure the look of your Web application outside of Manager, see the topic "Customizing the Web Mapping Application" in the ArcGIS Server .NET Developer Help.
If you want to further configure the settings for a map element, click its Settings button. A panel of options will appear for the element, which you can set to customize the way the element looks and behaves.
The following list defines the available map elements and provides tips for configuring each:
Overview Map - Shows the user's position on the main map relative to a smaller-scale inset map. In some cases, you might want your overview map and your main map to come from different map services. Be aware that if you use a cached map for the overview map, the smallest scale image will need to be resampled to fit the overview map size, and the display quality may be less than expected. To work around this, create the cache at a very small scale, or use a noncached service for the overview map.
You can set either a static or interactive mode for the overview map. By default, the mode is static, which results in the best performance. If your application requires that the overview map be closely in sync with the map, you can choose the interactive mode. In interactive mode, the overview map extent updates automatically whenever the Web application user zooms or pans the map. The user can also resize the area of interest box.
If the map service is already running, you must restart it for the changes to take effect. If you don't want to restart the service manually, it will automatically restart the next time recycling occurs. For more information on recycling, see the ArcGIS Server Help topic "Tuning and configuring services".
If you prefer not to edit the map document or if the map document is inaccessible to you, you can configure copyright text in Manager by clicking Map Copyright Text on the Map Elements panel or tab. The Label text displays as a link on the map and the Description appears in a popup window when you click the link. If you enter some Label text, you must also enter a Description.
It's also possible to use Manager to customize the Label text, while allowing the Description to come from the Credits box in the map document. In this scenario, you can leave the Description box blank.
Next topic: Choosing application settings
