Customizing the Web Mapping Application
Release 9.3.1 E-mail This Topic Printable Version Give Us Feedback
You can start the Web application generated by Manager in the Visual Studio IDE and continue to customize it to meet your specific needs. The Web Mapping Application is also integrated with Visual Studio as a template. Whether created in Manager or Visual Studio, a Web Mapping Application contains standard Web page design elements plus Web controls. These Web controls include both standard ASP.NET Web controls, as well as those specific to ESRI's Web ADF.
There are two general levels of customizing a Web Mapping Application:
Notes:
Comparing Manager with ArcIMS Designer
To better understand the functionality available in Manager, the following table compares functions in ArcIMS Designer and the corresponding function in Manager. In many cases, there is a one-to-one correspondence between the two, although the format and order are different.
Action Designer Manager
Set Web application name Type in name. Same
Set title for application Type in title. Same
Add services ArcIMS services only. The HTML Viewer allows only one service per viewer. The Java Custom and Java Standard viewers allow more than one ArcIMS service per viewer. Access to service is through HTTP(S). ArcIMS, ArcGIS Server, WMS. Services can be accessed from one or more sites. Access to ArcIMS services is through HTTP or TCP.
Set map extent Initial extent based on the extent of the service or on a layer in the service. Extent limit is the maximum extent allowed by service or layer. Custom extents allowed. Default extent is derived from the Primary Map Resource.
Select overview map Any image or ArcMap Image Service on the same server as the map. Can be any service.
Select scale bar Set data source and scale bar units. Set scale bar units and color.
Select toolbar (See below for more details on tools and tasks.) Select which tools to include in toolbar. Select whether to include toolbar or not.
Select tasks N/A Pick from Search, Query, Print, Find Address, and Find Place tasks.
Select north arrow Included by default. Selection provides look and feel for navigation tool.
Select table of contents Legend and layer list included by default. Select whether to include TOC, to include service in TOC, and to include swatches.
Select look and feel N/A Part of page elements.
Add Web links in title bar N/A Part of page elements.
Choose Web application location Default is virtual directory established during postinstall. Default is wwwroot directory.
Modify output No Yes
Tools and tasks
Many of the operations in the HTML Viewer, Java Standard Viewer, and Java Custom Viewer that are handled through the toolbar are also in the Web Mapping Application. However, in some cases, a new approach has been taken to handle some of the operations. One big difference is the use of tasks. The task framework offers a standard way to deliver GIS functionality in your Web Mapping Application. Besides making the out-of-the-box functionality easier to use, you can also use the model to build your own custom tasks. Each task is a unit of work where there is often a dialog box requiring user interaction. For example, in the HTML Viewer, when a user clicks the Find tool, a dialog box appears where the user can type in a search string. In the Web Mapping Application, there is no equivalent tool on the toolbar. Instead, a Search task can be configured that allows users to type in a search string. In addition to a Search task, other tasks available for ArcIMS users are Query, Print, Find Address, and Find Place.
The following table compares the tools available on the HTML Viewer, Java Standard Viewer, and Java Custom Viewer toolbars and the equivalent tools or tasks in the Web Mapping Application.
HTML Viewer, Java Custom Viewer, Java Standard Viewer Web Mapping Application
Toggle between legend and layer list Table of contents (TOC) includes layers and swatches together; included in a collapsible, dockable panel.
Toggle overview map Included in collapsible, dockable panel.
Zoom in, Zoom out, Pan Included on toolbar. Users can also use the scroll wheel or keyboard strokes.
Zoom to full extent Included on toolbar.
Zoom to active layer N/A. No concept of an active layer.
Back to last extent Included on toolbar.
Pan north, south, east, west Navigation tool allows users to pan the map.
Identify Included on toolbar.
Query Included as Query task.
Find Included as Search task.
Stored query Use a Query or Search task.
Measure Included on toolbar.
Set units Included as part of measure dialog.
Buffer See tip.
Select by rectangle, select by line or polygon See tip.
Find address Included as Find Address task.
Clear features Features are highlighted by turning on each selected feature individually. They are cleared by turning off each feature.
Print Included as Print task.
N/A Magnify tool on toolbar.
N/A Find place task.
Tip: Buffer and Select Features are not included on the toolbar. ArcGIS Server users can create a Geoprocessing task to support these operations. ArcIMS users can customize the Web Mapping Application to add these operations.
The ArcIMS Java Custom and Java Standard Viewers have the same tools as those listed for the HTML Viewer. They also have the following additional tools:
Java Custom or Standard Viewer Web Mapping Application
Open Project, Save Project, Close Project No equivalent when using a Web Mapping Appication. However, you can save, close, and open maps using ArcGIS Explorer.
MapTips Available through the Layers tab of Manager (on the Records tab of the Layer Properties dialog box).
Layer Properties Available through the Layers tab of Manager.
EditNotes An Editor task is available in Manager.
MapNotes Not available as part of Manager, but a Web Mapping Application could be customized to support similar functionality.
Customizing Web Mapping Applications
Further details about customizing Web Mapping Applications can be found in the Developer Help under the section "Customizing the Web Mapping Application.
