ArcGIS Server Banner
An overview of database server connections
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note:This topic was updated for 9.3.1.
ArcSDE database server connections are used for the creation and administration of ArcSDE geodatabases for SQL Server Express.
Before you can create geodatabases on a database server in ArcCatalog, you must connect to an ArcSDE database server. (A database server is an instance of SQL Server Express.) This involves the following:
Once you are connected to the database server, if you are a database server administrator, you can create geodatabases. You can create and administer multiple geodatabases on a database server. See the section "How to create a geodatabase on an ArcSDE database server" in the topic Creating a new geodatabase in the "Creating a geodatabase" section of the help.
When you reconnect to your database server, you always initially see the default versions of your geodatabases (DBO.DEFAULT). You can change versions, but if you frequently work with a version other than DEFAULT, you can save some steps by saving a connection to a particular version of the geodatabase.
Saving a geodatabase connection creates a connection file in the Spatial Database Connections folder that points to a particular version of the geodatabase. This allows you to reconnect to that version of the database without having to first connect to the database server and change the version of the geodatabase you are viewing. See Saving a geodatabase connection for instructions.
See Also
  • An overview of ArcSDE geodatabase connections
  • Adding an ArcSDE database server
  • Deleting an ArcSDE database server
  • Disconnecting from an ArcSDE database server
  • Pausing, stopping, and starting an ArcSDE database server
  • Saving a geodatabase connection
