Note: This topic was updated for 9.3.1.
You can use ArcCatalog to add subtypes and set default values and attribute domains for the fields of each subtype.
You can manage subtypes using the properties dialog box for each table or feature class. You can define the subtype field, add new subtypes, and remove or modify existing subtypes.
