ArcGIS Server Banner
Geodatabase releases and geodatabase replication (ArcInfo and ArcEditor only)
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note: This topic was updated for 9.3.1.
Geodatabases built using previous versions of ArcGIS do not support some of the newer functions of ArcGIS. Consequently, if your organization has both ArcGIS 9.3 geodatabases and geodatabases from an earlier release, consider the following:
For all replication types, the child replica geodatabase must have a geodatabase release that's the same as or greater than the parent replica geodatabase. This means
NOTE: If you upgrade the parent replica's geodatabase, you will also need to upgrade the child replica's geodatabase before synchronizing. For example, consider the case where you create a checkout replica using an 9.2 geodatabase to host both the parent and the child. If you then upgrade the parent's geodatabase to 9.3, you will need to upgrade the child's geodatabase before synchronizing. If synchronizing using a delta file, you will need to upgrade the child's geodatabase and then reexport the delta file.
NOTE: There is one exception to these rules. If the parent replica's data is stored in high precision in a 9.2 or greater geodatabase, you can't create a checkout replica using a low-precision 9.2 or greater geodatabase for the child.
Additional requirements for two-way and one-way replicas
Two-way and one-way replicas were introduced with ArcGIS 9.2 and require a 9.2 or greater geodatabase for both the parent and child replicas although, as stated above, the child replica geodatabase must have the same geodatabase release or greater than the parent replica geodatabase.
If you have ArcGIS 9.3 or ArcGIS 9.2 SP5, you can create two-way and one-way replicas as long as the geodatabases are 9.2 or greater.
If you have ArcGIS 9.2 SP4 or earlier, you can only create two-way and one-way replicas with 9.2 geodatabases.
