ST_Is3d takes a geometry as an input parameter and returns 1 if the given geometry has z-coordinates or 0 if it does not.
sde.st_is3d (g1 sde.st_geometry)
This example creates a table, is3d_test, and populates it with records. Then, using ST_Is3d, it checks to see if any of the records has a z-coordinate.
CREATE TABLE is3d_test (id integer, geometry sde.st_geometry);
INSERT INTO is3d_test VALUES (
1902,
sde.st_geometry ('polygon ((40 120, 90 120, 90 150, 40 150, 40 120))', 0)
1903,
sde.st_geometry ('multipoint m(10 10 5, 50 10 6, 10 30 8)' , 0)
1904,
sde.st_geometry ('linestring z(10 10 166, 20 10 168)', 0)
1905,
sde.st_geometry ('point zm(10 10 16 30)', 0)
SELECT id, sde.st_is3d (geometry) Is_3D
FROM is3d_test;
ID IS_3D
1902 0
1903 0
1904 1
1905 1
