Note:This topic was updated for 9.3.1.
NOTE: Applies to geodatabases created with an ArcGIS Server Enterprise license only
Stopping the ArcSDE service relinquishes all of its processes and operating system resources. You can stop an ArcSDE service if no server tasks are running. If server tasks are running, you must remove the running tasks before the service will shut down. See
Removing ArcSDE service user processes for information ending user processes.
There are different reasons why you might need to stop the ArcSDE service, such as if the giomgr process stalls or if you change an environment variable and need to stop then restart the service for the variable to take effect.
On local Windows servers, you can stop the ArcSDE service from within the Services menu.
You can use the sdemon command to shut down the service on Windows or UNIX platforms. When the ArcSDE service is shut down, the sdemon command notes any ArcSDE processes still running and prompts for confirmation that these tasks should be terminated before continuing with the shutdown. For details on the use of sdemon and other administration commands, consult the Administration Command Reference that is provided with the ArcSDE component of ArcGIS Server Enterprise. You can also download a PDF version of the file from the
Geodatabase Resource Center.
Clients that attempt to connect using an ArcSDE service while the service is stopped will receive the following error message:
"Failed to connect to the specified server.
SDE not running on server"
NOTE: Users connecting via a direct connection are not blocked when the ArcSDE service is shut down.
- At an MS-DOS command prompt, type the sdemon command using the shutdown operation and specify the port number of the remote service and the server name. You will be prompted to provide the password of the ArcSDE administrator user.
sdemon –o shutdown –i 4300 –s our_server
Please enter ArcSDE DBA password:
ArcSDE Instance 4300 on our_server is Shutdown!
- Type the sdemon command with the status operation to confirm the ArcSDE service has been shut down.
sdemon –o status –i 4300 –s our_server
ArcSDE instance 4300 is not available on our_server.
Tips
- Any user can run the sdemon status operation, so a password is not necessary.
- You can use the service name instead of the service port with the –i option; however, if you do, the service name and port have to be in the Windows services file on the computer from which you are running the sdemon command.
- Right-click the Windows taskbar and click Task Manager. Identify the process ID (PID) of the stalled giomgr process.
- Type "killp" at the MS-DOS command prompt. Include the PID obtained from the Task Manager window. When prompted, confirm your intent to kill the process by typing "y".
C:\> cd %SDEHOME%\tools
C:\%SDEHOME%\tools> killp 100
Do you really want to kill process with pid 100(y/n)
y
- At a shell command prompt, type the sdemon command using the shutdown operation. If you are not using the default service name and port, provide it with the command. You will be prompted to provide the ArcSDE administrator password.
sdemon –o shutdown –i 2468
ArcSDE Instance 2468 on <local_server> is Shutdown!
sdemon –o status –i 2468
ArcSDE Instance 2468 on <local_server> is not available.
- At a shell prompt, type the sdemon command using the shutdown operation. Specify the port number of the remote service and the server name. You will be prompted to provide the password of the ArcSDE administrator user.
sdemon –o shutdown –i 5678 –s gis_server
ArcSDE Instance 5678 on gis_server is Shutdown!
sdemon –o status
ArcSDE instance 5678 is not available on gis_server.
Tip
- Identify the PID of the stalled ArcSDE service or giomgr process using the UNIX ps -ef command that was piped through grep to isolate the giomgr process.
ps -ef | grep giomgr
arcsde 3403 1 0 06:00:03 ? 0:03
/prod/sdeexe91/bin/giomgr /prod/sdeexe91
- Type the UNIX kill command. Include the PID to terminate the giomgr process.
kill -9 3403
