Log codes overview |
| Release 9.3.1 |
Log code number ranges are associated with certain types of messages. Codes below 10000 are logged by the server object manager (SOM). Codes between 10000 and 100000 pertain to services, and codes above 100000 are core ArcObjects component-related messages that may also be used in ArcGIS Engine or ArcGIS Desktop. The following table shows a more detailed breakdown of the code ranges and their content:
| Log code range | Message content |
| 0-9999 | Core server (SOM) |
| 10000-10999 | Map services |
| 11000-11999 | Mobile data services |
| 12000-12999 | KML services |
| 13000-13999 | Network Analysis services |
| 14000-14999 | WFS services created from map services |
| 15000-15999 | WCS services created from map services |
| 16000-16999 | WMS services created from map services |
| 20000-20999 | Geoprocessing services |
| 21000-21999 | Synchronous geoprocessing services |
| 30000-30999 | Globe services |
| 60000-60999 | Geometry services |
| 70000-70999 | Geocode services |
| 80000-80999 | Image services |
| 81000-81999 | WCS services created from image services |
| 82000-82999 | WMS services created from image services |
| 90000-90999 | Geodata services |
| 91000-91999 | WCS services created from geodata services |
| 92000-92999 | WFS services created from geodata services |
| 100000-100999 | System |
| 101000-101999 | Geometry |
| 102000-102999 | Geodatabase |
| 103000-103999 | Carto |
| 104000-104999 | Display |
| 105000-105999 | Output |
| 106000-106999 | Geoprocessing |
| 107000-107999 | Globe |
| 108000-108999 | 3D |
| 109000-109999 | Network Analyst |
Some codes can apply to messages of different levels; for example, a message with a code may be an error for one event, while it may be a warning for another event.
