Performance tips for Web applications |
| Release 9.3.1 |
Performance of a Web application involves both the speed at which the application responds to users and the number of users that an application can accommodate. When you think about improving the performance of your ArcGIS Server Web applications, the first thing that may come to mind is adding or upgrading hardware. However, there may be other things you can adjust in your application, your map, or your server settings that will improve the performance of your Web applications.
Designing maps for the Web is much different than designing paper maps, or even maps that you commonly work with in desktop applications such as ArcMap. If you have a map document that you commonly use in ArcMap, you may want to save a copy instead of publishing the map directly to ArcGIS Server. Using the copy, you can make some optimizations specifically for Web viewing.
What's so different about maps that you'll view on the Web? To get the best performance of your map over the Web, it's recommended that you use the Map Service Publishing Toolbar in ArcMap to examine your map document. Resolve all the Errors and as many of the Warnings as you can, then publish the map using the toolbar. This bases your service on a map service definition (.msd) file which is the way to publish your service for the fastest drawing available.
Regardless of whether your map service is MSD-based, you should still consider caching it for performance. Caching a map means that you create and store a set of prerendered map images that can very quickly be used by the application instead of waiting for the map to draw each time. If caching the map, you'll need to design the map to look good at all the scales at which it will be cached. See Planning a map cache for ideas on how to do this.
By caching your map services, you will reduce the time that it takes for your map to draw. Whenever possible, try to cache all of the services in your application and avoid combining cached and non-cached services. However, at 9.3, the display speed of maps in which non-cached and cached services are overlayed has been greatly improved.
The image format that you choose affects the performance, appearance, and size on disk of your cache. PNG 8 works well for many MXD-based overlay services, while PNG 32 is a better choice for MSD-based overlay services. For base maps, JPEG is often the best choice, especially if the map has a lot of color variation. See Choosing cache properties to learn more about each image format.
Internet Explorer 6 has limitations in its ability to display transparency for PNG 24 images. The Web ADF includes code that works around this limitation, but there is a performance penalty incurred when this scenario is encountered. Avoid this scenario by:
Connect to your server using ArcGIS Server Internet connections to make more efficient use of server context requests. ArcGIS Server Local connections should be used only when the application requires changing the state of the service, which includes editing data.
If your overview map appears to be slowing performance by constantly changing its scale and extent, open your Web application in Visual Studio and set the OverviewMap control's StaticMode property to True. This is the default for ArcGIS Server 9.3 Web applications. By setting StaticMode to True, the image in the OverviewMap will not change when the Map extent changes.
The TOC control has several options that allow you to reduce the amount of information requested from the server.
Consider setting the Visible property on some of your MapResourceItems to False. This will result in the application opening faster and will the Web page user will need to turn on the layers manually.
The default Web Mapping Application that you see in Manager or your IDE includes Web controls such as the Table of Contents (TOC), OverviewMap and Scalebar. As you interact with your application, these controls request new images and updated status information. Eliminating controls from the application that are rarely used will help improve the application performance and scalability of the system.
When preparing your deployment environment, you need to make changes to avoid overworking the Local Security Authority Subsystem Service (lsass.exe).
When someone makes a request from one of your web services, the web server must authenticate itself with the Server Object Manager (SOM). The web server accomplishes this by impersonating the ArcGIS Web Services account, which was added to the AGSADMIN group when you ran the post install. This impersonation doesn't cost much under light loads, but under heavy loads the lsass.exe process can become overworked, causing a noticeable lag in performance. Heavy loads are considered 25 or more requests per second.
You can avoid this per-request impersonation by configuring your web services to run in an application pool that runs under the identity of the ArcGIS Web Services account. This lightens the load on the lsass.exe process and ultimately allows your services to run faster.
These ESRI Knowledge Base articles give additional background on the problem and describe how to make the adjustments to your configuration.
If you are customizing the Web mapping application in Microsoft Visual Studio or creating your own application from scratch, use the coding best practices in Guidelines for creating your own Web applications in the Developer Help.
ArcGIS Server map services limit the number of records that can be returned by a query to 500 by default. Keep this value or lower it for optimal performance with queries. You can change the number of allowable result records by editing the MaxRecordCount property in the map service configuration file.
Use caution if you raise the default value. Queries that return more than 2000 records require the software to create scratch workspaces in your system TEMP directory to manage the result records. This can cause performance to degrade.
Using local paths to source maps and data tends to give better performance than using network or Universal Naming Convention (UNC) paths. If you use local paths and have more than one server object container (SOC) machine in your deployment, you'll need to duplicate the data on each machine using identical paths.
Another effective way to reference the data is through a central ArcSDE geodatabase. For example, you might store a (relatively lightweight) map document (.mxd) file on each SOC machine. In that map document, you could refer to source data stored in a common ArcSDE geodatabase. This way you wouldn't have to duplicate a large amount of data.
