Adding a new service |
Release 9.3.1 |
ArcGIS Server 9.3 offers seven service types: map, geocode, geodata, geometry, geoprocessing, globe, and image. Before you can create a service, you must create the GIS resource that it will access. For example, a map service uses a map document, so you must create the map document before creating the service.
This chart summarizes the GIS resource required for each type of service.
Service type | Required GIS resource |
Map service | Map document (.mxd, .pmf) or map service definition (.msd) |
Geocode service | Address locator (.loc, .mxs, SDE batch locator) |
Geodata service | Database connection file (.sde) or personal geodatabase or file geodatabase or map document with a layer that references data from a versioned geodatabase |
Geometry service | Does not require a GIS resource |
Geoprocessing service | Map document with a tool layer or toolbox (.tbx) |
Globe service | Globe document (.3dd, .pmf) |
Image service | Raster dataset or layer file referencing a raster dataset or compiled image service definition (.iscdef) |
There are two ways to create services in ArcGIS Server. In Manager, these options are Publish a GIS Resource and Add New Service. Choosing Add New Service allows you to set all the service properties at the time you create the service. In contrast, Publish a GIS Resource only prompts you for the minimum required information.
When you choose Add New Service you can only create one type of service at a time. For example, if you have a map document with a tool layer that you want to use to publish both a map service and a geoprocessing service, you must create the services individually if you use Add New Service. If you choose Publish a GIS Resource, you have the option to create the two services at the same time.
The following instructions explain how to use the Add New Service option. For help with using Publish a GIS Resource see Publishing a GIS resource to the server.
Note: When you choose Publish a map, globe, or other GIS resource as a service on the Home tab in Manager, this opens the Publish a GIS Resource wizard.
Click Add New Service.
Note: If this is the first time you're accessing the server, you'll need to add one or more server object container (SOC) machines to it before you can add a service.
If you're creating a geodata service, choose whether you want to create the service directly from a geodatabase or from a map document containing a layer from a geodatabase. If you are creating the service from the geodatabase directly, browse to the file geodatabase, personal geodatabase, or database connection file you'll be using. When you make a database connection in ArcCatalog, the connection information is stored in your profile directory (Example: C:\Documents and Settings\<username>\Application Data\ESRI\ArcCatalog\Connection to myServer.sde). It's a good idea to copy this file into a shared network directory to which all your container machines have read access. When creating the service, browse to this shared directory and choose the connection file.
If you're publishing the service from a map document containing a geodatabase layer, browse to that map document.
Once you've browsed to the database or map document, specify an output directory.
If you're creating a geoprocessing service, first choose whether the job will be performed synchronously (optimal for short jobs) or asynchronously (optimal for long jobs, and the results are stored on the server for future retrieval). Then, browse to either the toolbox or the map document containing the tool layer you want to publish. The results of the service can optionally be returned to the client as a map service, which you can choose from the Result Map Service drop-down list.
A geoprocessing service uses a jobs directory, which you must specify, as well as an associated virtual directory. For the jobs directory to be available, you must have specifically created it as a jobs directory using the Directories tab on the Server Properties dialog box. You'll also need to specify a server output directory in the same way.
Finally, you can specify whether to use a local jobs directory. If you choose this option, certain information will be stored in the SOC's system TEMP directory while the job is running. The information is copied it to the server jobs directory when the task is complete. This can improve performance if you have a multiple-machine deployment of ArcGIS Server.
If the type of service you chose has any available capabilities, a new page will appear where you can choose the capabilities you want to enable and set their properties. On this page, you can also choose whether Web access will be available for the service and the allowed operations for that Web access.
Learn more about operations (See the section "Limiting what users can do with a service")
Right-click the server or folder to which you want to add the service and click Add New Service.
A geoprocessing service use a jobs directory, which you must specify, as well as an associated virtual directory. For the jobs directory to be available, you must have specifically created it as a jobs directory using the Directories tab on the Server Properties dialog box. You'll also need to specify a server output directory in the same way.
