The deployment procedures below are for using Weblogic 9.1. The
procedures for using different versions may vary.
In Manager, locate the existing Web application on the
Applications page.
- Check the box next to the Web application you want to deploy to
Tomcat and hit the 'Export' button.
- In the File Download dialog that appears, click the Save
button.
- In the 'Save as type:' section, choose All
Files.
- The default file name extension will be .zip. Change this
to .war and save it to the file system. Click the
'Close' button when Save is complete. (For example:
/usr/home/temp/myapp.war)
- Start Weblogic Server. a browser will open to http://localhost:7001/index.jsp.
Click the 'Start the Administration Console' button to open the
Administration Console.
- In the Change Center section of the console, click the 'Lock
and Edit' button to open the server instance for changes.
- In the Domain Structure section of the console, find the
'Deployments' link and click on it.
- You will see a Summary of Deployments. Here is where you will
deploy the war file. Find and click the 'Install' button.
- Browse to the location on your file system where the .war file
was saved. Click the radio button next to the .war file and click
'Next'
- You want to deploy this module as an application. For the
targeting style, make sure 'Install this deployment as an application' is selected.
Click 'Next'.
- Click 'Next' again to
accept the defaults in this next pane, then click
'Finish'.
- You will now get a
summary list of the settings for the deployment. Click the 'Save'
button. If everything went ok, you will see a message in green that
says 'Settings updated
successfully.'
- Back in the Change Center section of the console,
click the green 'Activate Changes' button. The application has been
'prepared', but not yet deployed at this
point.
- Back in the Domain Structure section of the
concole, find and click on the 'Deployments' link. In the Summary
of Deployments, find your application, check the box next to it and
click the 'Start' button. Select 'Servicing all requests'. Click
Yes to continue
- If the state of your deployment says 'Active',
you have successfully deployed your Web application to
Weblogic.
- In the Domain Structure section of the console, click 'Deployments'.
- In the Summary of Deployments page, click on the name of the deployed Web application.
- Select the 'Test' tab. Here, you'll find the URL to the deployed Web application. Click the link to launch it in a separate browser window.
Testing your deployment from within the Weblogic Administration Console
You can test your
application from within the Administrative Console by following the
steps below:
