ArcGIS Server Banner
Log file tables in a geodatabase in SQL Server
Release 9.3 E-mail This TopicPrintable VersionGive Us feedback
Note:This topic was updated for 9.3.1.
A geodatabase uses log file tables to store lists of table rows.
See Log file configuration options for details on log file tables.
Log file tables in ArcCatalog and ArcMap
You will not see log file tables in ArcCatalog or ArcMap. However, you will cause log file tables to be created and populated when you make a selection in ArcMap that returns a set of more than 100 features.
Log file tables in a SQL Server DBMS
When you first install ArcSDE and create your geodatabase in SQL Server, the default log file configuration uses session-based log files created in the SQL Server tempdb database. Each client session that requires a log file table will have one dedicated log file table in this database. Therefore, if you use this default configuration, the session log file tables will not appear in your geodatabase.
If you alter your log file configuration from the default, you will see different log file tables in the geodatabase depending on to what your log file configuration is changed. If you use session-based log files created in the geodatabase instead of tempdb, you will see the SDE_logfiles, SDE_logfile_data, and SDE_session<SDE_ID> tables in the geodatabase. These tables will be created in the schema of the user whose session caused the tables to be created. Although created, the SDE_logfile_data table is not populated. The SDE_logfiles and SDE_logfile_data tables remain in the geodatabase but the SDE_logfiles table is truncated when the connecting application disconnects. The SDE_session<SDE_ID> table is truncated when the connecting application no longer needs the log file records (for ArcMap, this means there is no longer a selection set), and the table is dropped when the session disconnects.
Dashed lines in the following diagrams indicate an implicit relationship between tables.
ArcSDE session-based log file tables in SQL Server
If you use stand-alone log files, for each selection set above the selection threshold made by a session, a new SDE_logdata<SDE_ID>_<#> table is created for each layer. The SDE_logfiles and SDE_logfile_data tables are also created per session, but the SDE_logfile_data table isn't populated. Both of these tables are created in the schema of the user who caused them to be created.
The SDE_logdata<SDE_ID> tables are truncated when the connecting session no longer needs the log files, and the tables are dropped when the session disconnects. The SDE_logfiles table is truncated when the connecting application disconnects.
ArcSDE stand-alone log file tables in SQL Server
If you use shared log files, two tables per DBMS user ID are created and stored in the schema of that DBMS user—SDE_logfiles and SDE_logfile_data. Once created, these tables remain in the geodatabase; however, all log file entries are deleted when the connecting application deletes all its log files.
ArcSDE shared log file tables in SQL Server
The SDE_LOGFILE_POOL table is created and stored in the schema of the ArcSDE administrator when the geodatabase is created. If you use a pool of stand-alone or session-based log files owned by the ArcSDE administrator, this table will be used, plus SDE_LOGPOOL_<table_ID> tables will be created in the geodatabase. The number of SDE_logpool_<table_ID> tables created depends on the number you specify for the LOGFILEPOOLSIZE in the SDE_server_config table. In the example below, LOGFILEPOOLSIZE is set to 10; therefore, SDE_logpool tables 1 through 10 are created. In the SDE_logfiel_pool table for this example, there would be 10 records, with table_ids 1 through 10.
All the tables created for pools of log files are created in the ArcSDE administrator's schema.
A pool of ArcSDE log file tables in SQL Server
NOTE: If MAXSTANDALONELOGS is set to a number greater than 0, and a user that has CREATE TABLE permissions creates a selection set that exceeds the threshold for log files to be created, a stand-alone log file table will be created in that user's schema.
The following are the definitions for the tables that are used for ArcSDE log files.
The SDE_logdata<SDE_ID>_<#> table contains the list of business table records that are part of a stand-alone log file. <SDE_ID> denotes the session ID and <#> denotes the stand-alone log file sequence. These tables are stored in the user's schema.
Field name Field type Description
sde_row_id int The row ID or shape ID of the business table row being logged; log files can log either row IDs or shape IDs.
SDE_logfile_data
The SDE_logfile_data table contains the list of business table records that are part of each log file. It is stored in the user's schema.
logfile_data_id int Identifies the log file to which the row ID belongs.
The logfile_data_id is a reference to the log file metadata in SDE_logfiles.
SDE_logfile_pool
The SDE_logfile_pool table maintains the list of log files currently checked out. This table exists when the geodatabase is created and is stored in the schema of the ArcSDE administrator.
table_id int Identifies the log file pool table.
sde_id int Identifies which SDE connection is currently using the given log file pool table.
The sde_id is a reference to the sde_id column of the process_information table. If sde_id is NULL, it means this log file pool table is not currently in use.
Nulls allowed.
SDE_logfiles
The SDE_logfiles table contains the log file metadata and is stored in the user's schema.
logfile_name nvarchar(255) A unique user-defined (or application-defined) name for the log file.
logifle_id int Uniquely identifies the log file.
Primary key.
registration_id int The registration ID of the business table for which IDs are being logged in this log file.
flags int A bit mask of values that indicate properties of the log file.
session_tag int A unique identifier for a connection's session, which allows a given ArcSDE connection to purge all temporary log files belonging to its session, for example.
logfile_data_db nvarchar(32) The name of the database in which the table that's holding the IDs for this log file is stored.
Nulls allowed.
logfile_data_owner nvarchar(32) The name of the owner of the table that's holding the IDs for this log file.
Nulls allowed.
logfile_data_table nvarchar(32) The name of the table that is holding the IDs for this log file.
This could be the traditional SDE_logfile_data or a log pool table, a session table, or a stand-alone SDE_logdata<SDE_ID>_<#> table.
Nulls allowed.
column_name nvarchar(32) The name of the column in the business table that is being logged.
Generally, this is the row ID or shape iID, but you can also specify an arbitrary integer column to be logged.
Nulls allowed.
SDE_logpool_<table_id>
The SDE_logpool_<table_id> table can be checked out by users and stores either stand-alone or session-based log files. The <table_id> is the sequence number. These tables are only present if you are using pools of log files owned by the ArcSDE administrator.
SDE_session<SDE_ID>
The SDE_session<SDE_ID> table is created when you are using session-based log files. This table is used to track log file records when a connected session creates a selection set that exceeds the application threshold (100 records in ArcMap). The SDE_session<SDE_ID> table is dropped when the session disconnects.
Primary key.
Primary key.
Log file tables in an XML document
Log file tables do not appear in an XML document.
