LOGFILE DEFAULTS for Informix
| Release 9.3 |
Note:This topic was updated for 9.3.1.
The following are the default log file parameters as they would appear in the dbtune.sde file. You can alter the setting for these parameters in the dbtune.sde file prior to creating the geodatabase, or you can use the sdeconfig command to set them after the geodatabase is set up. Consult the ArcSDE Administration Command Reference included with the ArcSDE component of ArcGIS Server Enterprise for details on the sdeconfig command.
##LOGFILE_DEFAULTS
UI_TEXT "LOGFILE_DEFAULTS"
LF_STORAGE "EXTENT SIZE 16 NEXT SIZE 16 LOCK MODE ROW"
LF_INDEXES "FILLFACTOR 90"
LD_STORAGE "EXTENT SIZE 16 NEXT SIZE 16 LOCK MODE ROW"
LD_INDEX_DATA_ID "FILLFACTOR 90"
LD_INDEX_ROWID "FILLFACTOR 90"
SESSION_STORAGE "EXTENT SIZE 16 NEXT SIZE 16 LOCK MODE ROW"
SESSION_INDEX "FILLFACTOR 90"
SESSION_TEMP_TABLE "0"
END
