LOGFILE DEFAULTS for DB2
| Release 9.3 |
Note:This topic was updated for 9.3.1.
The following are the default log file parameters as they would appear in the dbtune.sde file. To provide storage information for the parameters that are commented out, uncomment them by removing the pound sign (#) and provide either a table space name (DB2 for Linux, UNIX, and Windows) or database subsystem name (DB2 for z/OS). Uncomment and set these parameters in the dbtune.sde file prior to creating the geodatabase. If you do not alter the values prior to geodatabase creation, you can use the sdeconfig command to set them after the geodatabase is set up. Consult the ArcSDE Administration Command Reference included with the ArcSDE component of ArcGIS Server Enterprise for details on the sdeconfig command.
##LOGFILE_DEFAULTS
LD_INDEX_DATA_ID ""
LD_INDEX_ROWID ""
#LD_STORAGE "IN <TABLESPACE> INDEX IN <TABLESPACE>"
#LF_STORAGE "IN <TABLESPACE> INDEX IN <TABLESPACE>"
UI_TEXT "LOGFILES"
#SESSION_STORAGE "IN <TABLESPACE> INDEX IN <TABLESPACE>"
#SESSION_INDEX ""
SESSION_TEMP_TABLE "0"
END
DB2 for z/OS
LD_INDEX_DATA_ID ""
LD_INDEX_ROWID ""
#LD_STORAGE "IN DATABASE <DATABASE NAME>"
#LF_STORAGE "IN DATABASE <DATABASE NAME>"
#SESSION_STORAGE "IN DATABASE <DATABASE NAME>"
#SESSION_INDEX ""
END
