Note:This topic was updated for 9.3.1.
NOTE: Applies to geodatabases created with an ArcGIS Server Enterprise license only
ArcGIS users can specify configuration keywords when they create datasets. To make configuration keywords accessible to ArcGIS Desktop users, you must have a user interface (UI) storage parameter in the configuration keyword's parameter group. Any configuration keywords that do not have a UI storage parameter will not be available to the ArcGIS users.
The UI storage parameters are
UI_TEXT—General user interface storage parameter; to be used with any keyword, other than network or topology keywords, you want to make available to users
UI_NETWORK_TEXT—User interface storage parameter for a parent network keyword
UI_TOPOLOGY_TEXT—User interface storage parameter for a parent topology keyword
UI_TERRAIN_TEXT—User interface storage parameter for a parent terrain keyword
These parameters are present in most of the keyword parameter lists of the default dbtune.sde file. However, if you create your own keywords that you want to be available to ArcGIS users, you should add the appropriate UI storage parameter to the keyword's parameter list.
NOTE: A UI storage parameter is not needed and should not be added to the DATA_DICTIONARY configuration keyword parameter list. The DATA_DICTIONARY configuration keyword is used to specify storage of the ArcSDE geodatabase system tables and cannot be used for datasets.
Some rules about adding user interface storage parameters
- If there are no UI storage parameters in a configuration keyword parameter group, the configuration keyword will not be recognized by ArcGIS or ArcObjects.
- You shouldn't have more than one UI parameter per configuration keyword. For example, you shouldn't have both UI_TEXT and UI_NETWORK_TEXT in the same configuration keyword parameter group.
- If multiple UI storage parameters are present, ArcGIS will only recognize one of them. If UI_TEXT and UI_NETWORK_TEXT, UI_TOPOLOGY_TEXT, or UI_TERRAIN_TEXT are in the same group, UI_TEXT will be ignored and the other parameter will be recognized. For example:
##SDO_GEOMETRY
GEOMETRY_STORAGE "SDO_GEOMETRY"
ATTRIBUTE_BINARY "BLOB"
RASTER_STORAGE "SDO_GEORASTER"
SDO_COMMIT_INTERVAL 1000
UI_TEXT "User Interface text description for SDO_GEOMETRY"
UI_NETWORK_TEXT "User Interface network text description for
SDO_GEOMETRY keyword"
END
In this case, UI_NETWORK_TEXT will be used, mistakenly indicating this is a parent network keyword.
If more than one of the following is present in the same group: UI_NETWORK_TEXT, UI_TOPOLOGY_TEXT, and UI_TERRAIN_TEXT, the first UI parameter encountered for that keyword in the DBTUNE table will be used and the subsequent UI parameter ignored. For example:
##NETWORK_DEFAULTS
UI_TOPOLOGY_TEXT "User Interface topology default configuration"
UI_NETWORK_TEXT "User Interface network default configuration"
B_STORAGE "PCTFREE 0 INITRANS 4"
# TABLESPACE <Network default business table tablespace name>
<additional parameters>
Here, UI_TOPOLOGY_TEXT will be read first, mistakenly indicating this is a parent topology keyword.
To add a UI configuration parameter to the DBTUNE table
- Export the DBTUNE table to the dbtune.sde file using the sdedbtune –o export command.
- Open the dbtune.sde file in a text editor.
- Locate or create the configuration keyword that you want to make available in the ArcGIS user interface.
- If the keyword is used to build tables, feature classes, and indexes, add the UI_TEXT storage parameter to the parameter list. If the keyword is a parent network keyword, add the UI_NETWORK_TEXT storage parameter. If the keyword is a parent topology keyword, add the UI_TOPOLOGY_TEXT storage parameter.
- Overwrite the DBTUNE table with the new information by importing the altered dbtune.sde file using the sdedbtune –o import command.
Tips
- See the Administration Command Reference installed with the ArcSDE component of ArcGIS Server Enterprise for details on how to use the sdedbtune command.
- You won't be able to programmatically access a configuration keyword using ArcObjects if there is no UI parameter specified.
- See Composite configuration keywords for details about parent keywords.
