Raster datasets and raster catalogs in a geodatabase stored in Oracle |
Release 9.3 | ![]() ![]() ![]() |
NOTE: Beginning with Oracle 11g, LONG RAW data types are no longer supported. Therefore, ESRI recommends you do not create new raster datasets using LONG RAW storage.
NOTE: You will only have the raster tables in your geodatabase if you have raster data in the geodatabase.
SDE_AUX_<raster_column_ID>The raster auxiliary table stores the image color map, image statistics, and the optional bit mask, which is used for image overlays and mosaicking.Field name | Field type | Description |
RASTERBAND_ID | NUMBER(38) | A number that represents a raster band; for example, a raster dataset with two raster bands would have two different values in this field—1 and 2 NOT NULL |
TYPE | NUMBER(38) | Values include 2 = raster statistics 3 = color map 4 = coordinate transformation 5 = reserved for geodatabase 6 = miscellaneous NOT NULL |
OBJECT | LONG RAW or BLOB | Contains the actual data, either a color map index, raster statistics, or coordinate transformation NOT NULL |
RRD_FACTOR | NUMBER(38) | Pyramid level; pyramid levels begin at 0 and can increase from there NOT NULL |
ROW_NBR | NUMBER(38) | Tile row number position NOT NULL |
COL_NBR | NUMBER(38) | Column row number position NOT NULL |
BLOCK_DATA | LONG RAW or BLOB | Pixel data stored in the tile NOT NULL |
SEQUENCE_NBR | NUMBER(38) | Sequence of the raster band within the raster dataset NOT NULL |
RASTER_ID | NUMBER(38) | The unique identifier of the raster dataset; corresponds to the value in the raster column of the business table NOT NULL |
NAME | VARCHAR2(65) | The optional raster band name |
BAND_FLAGS | NUMBER(38) | A bit mask containing properties about the band NOT NULL |
BAND_WIDTH | NUMBER(38) | The pixel width of the band NOT NULL |
BAND_HEIGHT | NUMBER(38) | The pixel height of the band NOT NULL |
BAND_TYPES | NUMBER(38) | A bit mask containing properties about the band NOT NULL |
BLOCK_WIDTH | NUMBER(38) | The pixel width of a block NOT NULL |
BLOCK_HEIGHT | NUMBER(38) | The pixel height of a block NOT NULL |
BLOCK_ORIGIN_X | NUMBER(64) | The x-coordinate of the raster origin NOT NULL |
BLOCK_ORIGIN_Y | NUMBER(64) | The y-coordinate of the raster origin NOT NULL |
EMINX | NUMBER(64) | The minimum x-value of a raster band; with eminy, emaxx, and emaxy, defines the envelope of a raster band NOT NULL |
EMINY | NUMBER(64) | The minimum y-value of a raster band; with eminx, emaxx, and emaxy, defines the envelope of a raster band NOT NULL |
EMAXX | NUMBER(64) | The maximum x-value of a raster band; with eminx, eminy, and emaxy, defines the envelope of a raster band NOT NULL |
EMAXY | NUMBER(64) | The maximum y-value in a raster band; with eminx, eminy, and emaxx, defines the envelope of a raster band NOT NULL |
CDATE | NUMBER(38) | The creation date of the raster band NOT NULL |
MDATE | NUMBER(38) | The last modification date of the raster band NOT NULL |
RASTER_FLAGS | NUMBER(38) | Reserved for future use |
DESCRIPTION | VARCHAR2(65) | The description of the raster dataset |
Name | Example component value |
RASTER | SDO_GEORASTER |
RASTERTYPE | 20001 |
SPATIALEXTENT | SDO_GEOMETRY |
SDO_GTYPE | 2003 |
SDO_SRID | NULL |
SDO_POINT | NULL |
SDE_ELEM_INFO | SDO_ELEM_INFO_ARRAY(1,1003,3) |
SDO_ORDINATES | SDO_ORDINATE(0,0,0256,256) |
RASTERDATATABLE | 'SDE_RDT_1897' |
RASTERID | 2 |
METADATA | XMLTYPE(<georasterMetadata xmlns="http://xmlns.oracle.com/spatial/georaster"> <objectI) |
NOTE: The metadata column is very long, so to view it with SQL*Plus, you must increase both the LONGSIZE and PAGESIZE SQL*Plus environments and query it directly as follows:
set LONG 20000
set PAGESIZE 500
RASTERID | NUMBER |
PYRAMIDLEVEL | NUMBER |
BANDBLOCKNUMBER | NUMBER |
ROWBLOCKNUMBER | NUMBER |
COLUMNBLOCKNUMBER | NUMBER |
BLOCKMBR | MDSYS.SDO_GEOMETRY |
RASTERBLOCK | BLOB |
<esri:Workspace xmlns:esri="http://www.esri.com/schemas/ArcGIS/9.2" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xs="http://www.w3.org/2001/XMLSchema">
<WorkspaceDefinition xsi:type="esri:WorkspaceDefinition">
<WorkspaceType>esriRemoteDatabaseWorkspace</WorkspaceType>
<Version>sde.DEFAULT</Version>
<Domains xsi:type="esri:ArrayOfDomain" />
<DatasetDefinitions xsi:type="esri:ArrayOfDataElement">
<DataElement xsi:type="esri:DERasterDataset">
<CatalogPath>/V=sde.DEFAULT/RD=GDB.world_TIF</CatalogPath>
<Name>GDB.world_TIF</Name>
<Children xsi:type="esri:ArrayOfDataElement">
<DataElement xsi:type="esri:DERasterBand">
<CatalogPath>/V=sde.DEFAULT/RD=GDB.world_TIF/RB=Band_1</CatalogPath>
<Name>Band_1</Name>
<DatasetType>esriDTRasterBand</DatasetType>
<DSID>-1</DSID>
<Versioned>false</Versioned>
<CanVersion>false</CanVersion>
<HasOID>true</HasOID>
<OIDFieldName>ObjectID</OIDFieldName>
<Fields xsi:type="esri:Fields">
<FieldArray xsi:type="esri:ArrayOfField">
<Field xsi:type="esri:Field">
<Name>ObjectID</Name>
<Type>esriFieldTypeOID</Type>
<IsNullable>false</IsNullable>
<Length>4</Length>
<Precision>0</Precision>
<Scale>0</Scale>
<Required>true</Required>
<Editable>false</Editable>
</Field>
<Name>Value</Name>
<Type>esriFieldTypeInteger</Type>
<IsNullable>true</IsNullable>
<Length>0</Length>
<Scale>0</Scale>
</Field>
<Name>Count</Name>
<Length>0</Length>
<Scale>0</Scale>
</Field>
</FieldArray>
</Fields>
<Indexes xsi:type="esri:Indexes">
<IndexArray xsi:type="esri:ArrayOfIndex" />
</Indexes>
<IsInteger>true</IsInteger>
<MeanCellHeight>0.175996089009095</MeanCellHeight>
<MeanCellWidth>0.176000337991447</MeanCellWidth>
<Height>1024</Height>
<Width>2048</Width>
<PixelType>U8</PixelType>
<PrimaryField>1</PrimaryField>
<TableType>esriRasterTableValue</TableType>
<Extent xsi:type="esri:EnvelopeN">
<XMin>-179.906382261841</XMin>
<YMin>-90.1303147686327</YMin>
<XMax>180.542309944643</XMax>
<YMax>90.089680376681</YMax>
<SpatialReference xsi:type="esri:GeographicCoordinateSystem">
<WKT>GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]</WKT>
<XOrigin>-400</XOrigin>
<YOrigin>-400</YOrigin>
<XYScale>11258999068426.2</XYScale>
<ZOrigin>0</ZOrigin>
<ZScale>1</ZScale>
<MOrigin>0</MOrigin>
<MScale>1</MScale>
<XYTolerance>8.98315284119521E-09</XYTolerance>
<ZTolerance>2</ZTolerance>
<MTolerance>2</MTolerance>
<HighPrecision>true</HighPrecision>
<LeftLongitude>-180</LeftLongitude>
</SpatialReference>
</Extent>
</Data>
</DatasetData>
</WorkspaceData>
</esri:Workspace>
