NOTE: Applies to geodatabases created with an ArcGIS Server Enterprise license only
| Parameter name |
Description |
Values |
Notes |
| A_CLUSTER_RASTER |
Index type for raster column in Adds table |
1 or 01 = clustered
0 = nonclustered |
| A_CLUSTER_ROWID |
Index type for rowid column on Adds table |
1 or 01 = clustered
0 = nonclustered |
| A_CLUSTER_SHAPE |
Index type for Adds table shape column |
1 or0
1 = clustered
0 = nonclustered |
| A_CLUSTER_STATEID |
Index type for Adds table stated column |
1 or 01 = clustered
0 = nonclustered |
| A_CLUSTER_USER |
Index type for any user defined indexes on Adds table |
1 or 01 = clustered
0 = nonclustered |
| A_CLUSTER_XML |
Index type for xml doc type column of Adds table |
1 or 01 = clustered
0 = nonclustered |
| A_INDEX_RASTER |
1 or 01 = clustered
0 = nonclustered |
| A_INDEX_ROWID |
Adds table object ID column index storage definition |
See the SQL Server Books Online for CREATE INDEX parameters. |
| A_INDEX_SHAPE |
Adds table spatial column index storage definition |
| A_INDEX_STATEID |
Adds table sde_state_id column index storage definition |
| A_INDEX_USER |
Adds table index storage definition |
| A_INDEX_XML |
Adds table XML column index table storage definition |
| A_MS_SPINDEX |
Defines the spatial index for the Adds table of a versioned feature class that uses SQL Server 2008 Geometry storage |
GRIDS = (MEDIUM, MEDIUM, MEDIUM, MEDIUM), CELLS_PER_OBJECT = 16
For other possible values, consult the SQL Server documentation on spatial index creation. |
SQL Server spatial types only |
| A_STORAGE |
Adds table storage definition |
See the SQL Server Books Online for CREATE TABLE parameters. |
| A_TEXT_IN_ROW |
Amount, in bytes, of image (SE_blob) data type (vector or raster) to store directly in the data page of the table |
24–7,000
256 |
| AUX_CLUSTER_COMPOSITE |
Index type for primary key |
1 or 0
1 = clustered
0 = nonclustered |
| AUX_INDEX_COMPOSITE |
Raster AUX table composite column index storage definition |
| AUX_STORAGE |
Raster AUX table storage definition |
| B_CLUSTER_RASTER |
Index type for raster column in business table |
1 or 01 = clustered
0 = nonclustered |
| B_CLUSTER_ROWID |
Index type for rowid column on business table |
1 or 01 = clustered
0 = nonclustered |
| B_CLUSTER_SHAPE |
Index type for business table shape column |
1 or 0
1 = clustered
0 = nonclustered |
| B_CLUSTER_USER |
Index type for any user defined indexes on business table |
1 or 01 = clustered
0 = nonclustered |
| B_CLUSTER_XML |
Index type for xml doc type column of business table |
1 or 01 = clustered
0 = nonclustered |
| B_INDEX_RASTER |
Business table raster column index storage definition |
| B_INDEX_ROWID |
Business table object ID column index aster rowid index R<N>_SDE_ROWID_UK storage definition |
| B_INDEX_SHAPE |
Business table spatial column index storage definition |
| B_INDEX_TO_DATE |
Storage parameter info for creating the index R<registration_id>_sde_todate, which is used when updating the history table during an archive operation |
| B_INDEX_USER |
Business table user index storage definition |
| B_INDEX_XML |
Business table XML column index table storage definition |
| B_MS_SPINDEX |
Defines the spatial index for the business table of a feature class that uses SQL Server 2008 Geometry or Geography storage |
SQL Server spatial types (Geometry or Geography) only |
| B_STORAGE |
Business table and raster attribute table storage definition |
| B_TEXT_IN_ROW |
Amount, in bytes, of BLOB data stored in line |
24–7,000
256 |
| BLK_CLUSTER_COMPOSITE |
1 or 0
1 = clustered
0 = nonclustered |
| BLK_INDEX_COMPOSITE |
Raster BLK table composite column index storage definition |
| BLK_STORAGE |
Raster BLK table storage definition |
| BND_CLUSTER_COMPOSITE |
1 or 01 = clustered
0 = nonclustered |
| BND_CLUSTER_ID |
Index type for RASTER_ID, SEQUENCE_NBR columns |
1 or 01 = clustered
0 = nonclustered |
| BND_INDEX_COMPOSITE |
Raster BND table composite column index storage definition |
| BND_INDEX_ID |
Raster BND table RID column index storage definition |
| BND_STORAGE |
Raster BND table storage definition |
| COLLATION_NAME |
Collation of user-defined text columns |
Uses the database collation by default, unless other collation is specified |
| COMMENT |
Line used for comments |
Description up to 2048 characters |
| CROSS_DB_QUERY_FILTER |
Controls whether or not a connecting user can view rasters or feature classes across database boundaries; used only with multispatial database model |
1 or 0
1 = Can only view and access data in the database to which you have explicitly connected
0 = Can access data in other databases in the multispatial database |
| D_CLUSTER_ALL |
Index type for SDE_STATES_ID, SDE_DELETES_ROW_ID, and DELETED_AT column |
1 or 01 = clustered
0 = nonclustered |
| D_CLUSTER_DELETED_AT |
Index type for DELETED_AT column |
1 or 0
1 = clustered
0 = nonclustered |
| D_INDEX_ALL |
FILLFACTOR and location (file group) for composite index on SDE_STATES_ID, SDE_DELETES_ROW_ID, and DELETED_AT columns |
| D_INDEX_DELETED_AT |
Deletes table sde_deleted_at column index storage definition |
| D_STORAGE |
Deletes table storage definition |
| F_CLUSTER_FID |
Index type for FID column |
1 or 0
1 = clustered
0 = nonclustered |
| F_INDEX_AREA |
Feature table area column index storage definition |
Binary geometry storage only |
| F_INDEX_FID |
Feature table FID column index storage definition |
| F_INDEX_LEN |
Feature table length column index storage definition |
| F_STORAGE |
Feature table storage definition |
| F_TEXT_IN_ROW |
24–7000
256 |
| GEOMETRY_STORAGE |
Indicates storage type for spatial column; set this storage parameter to SDEBINARY, OGCWKB, GEOGRAPHY, or GEOMETRY for SQL Server |
SDEBINARY, OGCWKB, GEOGRAPHY, or GEOMETRY |
GEOMETRY and GEOGRAPHY can only be used with SQL Server 2008 databases. |
| GEOM_SRID_CHECK |
Adds a check constraint on the geometry column for an SRID value |
TRUE or FALSE |
| GEOMTAB_OUT_OF_ROW |
Specifies whether or not varchar(max), nvarchar(max), varbinary(max) are xml columns smaller than 8000 bytes are stored in the data row of the CAD side table |
1 or 01 = Stored out of row
0 = Stored in row |
CAD side tables only created if feature class uses GEOMETRY or GEOGRAPHY storage and is enabled to store CAD entities |
| GEOMTAB_PK |
Storage definition for the primary key index on the CAD table |
| GEOMTAB_STORAGE |
CAD table storage definition |
| LD_INDEX_ALL |
SDE_logfile_data and SDE_logpool tables primary key storage definition |
| LD_STORAGE |
SDE_logfile_data and SDE_logpool tables storage definition |
| LF_CLUSTER_ID |
Index type for SDE_logfiles primary key |
1 or 01 = clustered
0 = nonclustered |
| LF_CLUSTER_NAME |
Index type for unique index on table SDE_logfiles column log file_name |
1 or 01 = clustered
0 = nonclustered |
| LF_INDEX_ID |
SDE_logfiles primary key storage definition |
| LF_INDEX_NAME |
Storage definition for SDE_logfiles unique index |
| LF_STORAGE |
SDE_logfiles table storage definition |
| MVTABLES_MODIFIED_INDEX |
Mvtables_modified index storage definition |
| MVTABLES_MODIFIED_TABLE |
Mvtables_modified table storage definition |
| NUM_DEFAULT_CURSORS |
Controls the SQL Server cursor threshold |
-1 = All keysets are generated synchronously
0 = All cursor keysets are generated asynchronously
All other values = SQL Server Query Optimizer compares the number of expected rows in the cursor set to the number set in cursor threshold, then builds the keyset asynchronously if it exceeds the cursor threshold number. |
| PERMISSION_CACHE_THRESHOLD |
Controls amount of time (in milliseconds) the database can take to query the sysprotects table
If the PERMISSION_CACHE_THRESHOLD value is exceeded, a temporary table (cache) is created to store a user's permission and is used from then on. As long as PERMISSION_CACHE_THRESHOLD > 0,
the permission will be cached. If PERMISSION_CACHE_THRESHOLD = 0, it will not. |
0–1,000
250 |
| RAS_CLUSTER_ID |
Index type for primary key of RAS table |
1 or 0
1 = clustered
0 = nonclustered |
| RAS_INDEX_ID |
Raster RAS table RID index storage definition |
| RAS_STORAGE |
Raster RAS table storage definition |
| S_CLUSTER_ALL |
Index type for primary key (all columns of table) |
1 or 0
1 = clustered
0 = nonclustered |
| S_CLUSTER_SP_FID |
Fill factor and location (file group) for sp_fid column index |
| S_INDEX_ALL |
Spatial index table first index storage definition when using binary geometry storage |
| S_INDEX_SP_FID |
Spatial index table second index storage definition |
| S_STORAGE |
In Oracle and SQL Server databases, this parameter represents the spatial index table storage definition; in Informix databases, this parameter represents a "smart blob sbspace" |
| SESSION_TEMP_TABLE |
Controls whether or not log files get created in tempdb |
1 or 0
1 = create in tempdb
0 = don't create in tempdb |
| STATES_INDEX |
States table storage definition |
| STATES_LINEAGES_INDEX |
Controls the storage of the index on the SDE_state_lineages table's primary key |
| STATES_LINEAGES_TABLE |
State_lineages table storage definition |
| STATES_TABLE |
| UI_NETWORK_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of network configuration |
| UI_TERRAIN_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of terrain configuration |
| UI_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of associated noncomposite configuration keyword |
| UI_TOPOLOGY_TEXT |
User interface parameter, which indicates associated configuration keyword will appear in the ArcGIS user interface; contains description of topoology configuration |
| UNICODE_STRING |
Determines whether Unicode text types will be used or not; If set to TRUE, character fields will be stored in UNICODE compliant data types.
For example, if the UNICODE_STRING parameter is set to FALSE a string data type would be VARCHAR. If UNICODE_STRING is set to TRUE, the data type of the field would be NVARCHAR. |
TRUE or FALSE |
| VERSIONS_INDEX |
Version index storage definition |
| VERSIONS_TABLE |
Versions table storage definition |
| XML_DOC_INDEX |
Storage clause for xmldoc<n>_pk and xml_doc<n>_ix indexes on the sde_xml_doc<n> table |
| XML_DOC_MODE |
Storage type for XML documents |
COMPRESSED or UNCOMPRESSED |
| XML_DOC_STORAGE |
Storage clause for sde_xml_doc<n> table |
| XML_DOC_TEXT_IN_ROW |
Storage clause for storing XML document BLOB data in line; values in bytes |
24–7000
1024 |
| XML_DOC_UNCOMPRESSED_TYPE |
When the XML_DOC_MODE parameter is set to UNCOMPRESSED, the XML_DOC_UNCOMPRESSED_TYPE parameter determines the storage format for XML documents |
Since XML_DOC_MODE is set to COMPRESSED by default, the XML_DOC_UNCOMPRESSED_TYPE parameter is not present by default.
Possible values:
BINARY, TEXT, or UNICODE |
| XML_IDX_CLUSTER_DOUBLE |
Storage clause indicating if the xmlix<n>_db index on the double_tag column of the sde_xml_idx<n> table is clustered |
1 or 01 = clustered
0 = nonclustered |
| XML_IDX_CLUSTER_ID |
Storage clause indicating if the xmlix<n>_id index on the id column of the sde_xml_idx<n> table is clustered |
1 or 01 = clustered
0 = nonclustered |
| XML_IDX_CLUSTER_PK |
Storage clause indicating if the xmlix<n>_pk index on the xml_key_column identity column of the sde_xml_idx<n> table is clustered |
1 or 0
1 = clustered
0 = nonclustered |
| XML_IDX_CLUSTER_STRING |
Storage clause indicating if the xmlix<n>_st index on the string_tag column of the sde_xml_idx<n> table is clustered |
1 or 01 = clustered
0 = nonclustered |
| XML_IDX_CLUSTER_TAG |
Storage clause indicating if the xmlix<n>_tg index on the tag_id column of the sde_xml_idx<n> table is clustered |
1 or 01 = clustered
0 = nonclustered |
| XML_IDX_FULLTEXT_CAT |
Name of the full-text catalog in which the contents of the xml_doc_val column in the sde_xml_doc<n> table and the text_tag column of the sde_xml_idx<n> table are indexed |
The name you gave the full-text catalog when it was created; the default is SDE_DEFAULT_CAT.
If you gave the catalog any other name, you must change the value of this parameter to match it. |
| XML_IDX_FULLTEXT_LANGUAGE |
The language used for linguistic analysis when building the text index on the contents of the xml_doc_val column in the sde_xml_doc<n> table and the text_tag column of the sde_xml_idx<n> table |
There is no default value set for this parameter. Consult your DBMS documentation for valid language settings. |
| XML_IDX_FULLTEXT_TIMESTAMP |
Determines whether or not a timestamp column will be added to the sde_xml_idx<n> table |
1 or 0
1 = timestamp column will be added
0 = timestamp column will not be added |
| XML_IDX_FULLTEXT_UPDATE_METHOD |
Dictates how changes made to the xml_doc_val column in the sde_xml_doc<n> table (the XML document table) and the text_tag column of the sde_xml_idx<n> table (the index table of an XML column) are propagated to the full-text index |
CHANGE_TRACKING BACKGROUND or CHANGE_TRACKING MANUAL
| XML_IDX_INDEX_DOUBLE |
Storage clause for the xmlix<n>_db index on the double_tag column of the sde_xml_idx<n> table |
| XML_IDX_INDEX_ID |
Storage clause for the xmlix<n>_id index on the ID column of the xml_idx<n> table |
| XML_IDX_INDEX_PK |
Storage clause for xmlix<n>_pk index on the xml_key_column identity column of the sde_xml_idx<n> table |
| XML_IDX_INDEX_STRING |
Storage clause for xmlix<n>_st index on the string_tag column of the sde_xml_idx<n> table |
| XML_IDX_INDEX_TAG |
Storage clause for the xmlix<n>_tg index on the tag_id column of the sde_xml_idx<n> table |
| XML_IDX_STORAGE |
Storage clause for sde_xml_idx<n> table (the index table of an XML column) |
| XML_IDX_TEXT_IN_ROW |
Controls how much of the contents of the text_tag column in the sde_xml_idx<n> table (the index table of an XML column) can be stored in line; value in bytes |
24–7000
128 |
NOTE: For the XML parameters, <n> refers to the xml_column_id associated with a specific XML column.
NOTE: If you do not use XML columns and XML documents in your geodatabase, you don't need to configure these parameters.
