ST_Entity returns the spatial entity type of a geometry. The spatial entity type is the value stored in the entity member field of the ST_Geometry object.
sde.st_entity (g1 sde.st_geometry)
CREATE TABLE sample_geometries (id integer, geometry sde.st_geometry);
INSERT INTO sample_geometries (id, geometry) VALUES (
1901,
sde.st_geometry ('point (1 2)', 0)
INSERT INTO sample_geometries (id, geometry VALUES (
1902,
sde.st_geometry ('linestring (33 2, 34 3, 35 6)', 0)
1903,
sde.st_geometry ('polygon ((3 3, 4 6, 5 3, 3 3))', 0)
SELECT sde.st_entity (geometry) entity, UPPER (sde.st_geometrytype (geometry))
TYPE
FROM sample_geometries;
ENTITY TYPE
1 ST_POINT
4 ST_LINESTRING
8 ST_POLYGON
