ST_GeomFromText takes a well-known text representation and a spatial reference ID and returns a geometry object.
sde.st_geomfromtext (wkt clob, srid integer)
The geometry_test table contains the integer gid column, which uniquely identifies each row, and the g1 column, which stores the geometry.
CREATE TABLE geometry_test (gid smallint unique, g1 sde.st_geometry);
The INSERT statements insert the data into the gid and g1 columns of the geometry_test table. The ST_GeomFromText function converts the text representation of each geometry into its corresponding instantiable subclass. The SELECT statement at the end is done to ensure data was inserted into the g1 column.
INSERT INTO geometry_test VALUES (
1,
sde.st_geomfromtext ('point (10.02 20.01)', 0)
2,
sde.st_geomfromtext('linestring (10.01 20.01, 10.01 30.01, 10.01 40.01)', 0)
3,
sde.st_geomfromtext('polygon ((10.02 20.01, 11.92 35.64, 25.02 34.15,
19.15 33.94, 10.02 20.01))', 0)
4,
sde.st_geomfromtext('multipoint (10.02 20.01, 10.32 23.98, 11.92 25.64)', 0)
5,
sde.st_geomfromtext ('multilinestring ((10.02 20.01, 10.32 23.98,
11.92 25.64), (9.55 23.75, 15.36 30.11))', 0)
6,
sde.st_geomfromtext ('multipolygon (((10.02 20.01, 11.92 35.64,
25.02 34.15, 19.15 33.94, 10.02 20.01), (51.71 21.73, 73.36 27.04,
71.52 32.87, 52.43 31.90, 51.71 21.73)))', 0)
SELECT sde.st_astext(g1)
FROM geometry_test;
