ST_Length returns the length of an ST_LineString or ST_MultiLinestring.
Oracle
sde.st_length (ln1 sde.st_geometry)
sde.st_length (mln1 sde.st_geometry)
PostgreSQL
st_length (ln1 st_geometry)
st_length (mln1 st_geometry)
A local ecologist studying the migratory patterns of the salmon population in the county's waterways wants the length of all stream and river systems within the county.
The waterways table is created with the ID and name columns, which identify each stream and river system stored in the table. The water column is a multilinestring because the river and stream systems are often an aggregate of several linestrings.
Oracle
CREATE TABLE waterways (oid integer, name varchar(128), water sde.st_geometry);
INSERT INTO waterways VALUES (
1111,
'Genesee',
sde.st_multilinestring ('multilinestring ((33 2, 34 3, 35 6),
(28 4, 29 5, 31 8, 43 12), (39 3, 37 4, 36 7))', 0)
PostgreSQL
CREATE TABLE waterways (oid integer, name varchar(128), water st_geometry);
1111,
'Genesee',
The query returns the name of each system along with the length of the system generated by the ST_Length function.
Oracle
SELECT name, sde.st_length (water) "Length"
FROM waterways;
NAME	Length
Genesee	27.6437123
PostgreSQL
SELECT name, st_length (water) AS "Length"
FROM waterways;
name	Length
Genesee	27.6437123
