ST_MLineFromWKB creates an ST_MultiLineString from a well-known binary (WKB) representation of type ST_MultiLineString and a spatial reference ID.
Oracle
sde.st_mlinefromwkb (wkb blob, srid integer)
PostgreSQL
st_mlinefromwkb (wkb bytea, srid integer)
In the following example, the lines of results have been reformatted for readability. The spacing in your results will vary according to your online display. This example illustrates how ST_MLineFromWKB can be used to create a multilinestring from its well-known binary representation. The geometry is a multilinestring in spatial reference system 1. In this example, the multilinestring is stored with ID = 10 in the geometry column of the sample_mlines table, and the wkb column is updated with its well-known binary representation (using the ST_AsBinary function). Finally, the ST_MLineFromWKB function is used to return the multilinestring from the wkb column. The x- and y-coordinates for this geometry are v Line 1: (61, 2) (64, 3) (65, 6), v Line 2: (58, 4) (59, 5) (61, 8), and v Line 3: (69, 3) (67, 4) (66, 7) (68, 9). The sample_mlines table has a geometry column, where the multilinestring is stored, and a wkb column, where the multilinestring's WKB representation is stored.
Oracle
CREATE TABLE sample_mlines (id integer, geometry sde.st_geometry, wkb blob);
INSERT INTO sample_mlines (id, geometry) VALUES (
10,
sde.st_multilinestring ('multilinestring ((61 2, 64 3, 65 6), (58 4, 59 5, 61 8), (69 3, 67 4, 66 7, 68 9))', 0)
UPDATE sample_mlines
SET wkb = sde.st_asbinary (geometry)
WHERE id = 10;
PostgreSQL
CREATE TABLE sample_mlines (id integer, geometry st_geometry, wkb bytea);
10,
SET wkb = st_asbinary (geometry)
WHERE id = 10;
In the following SELECT statement, the ST_MLineFromWKB function is used to retrieve the multilinestring from the wkb column.
Oracle
SELECT id, sde.st_astext (sde.st_mlinefromwkb (wkb,0)) MULTI_LINE_STRING
FROM sample_mlines
WHERE id = 10;
ID    MULTI_LINE_STRING
10    MULTILINESTRING ((61.00000000 2.00000000, 64.00000000 3.00000000, 65.00000000 6.00000000), (58.00000000 4.00000000, 59.00000000 5.00000000, 61.00000000 8.0000000), (69.00000000 3.00000000, 67.00000000 4.00000000, 66.00000000 7.00000000, 68.00000000 9.00000000 ))
PostgreSQL
SELECT id, st_astext (st_mlinefromwkb (wkb,0)) AS MULTI_LINE_STRING
FROM sample_mlines
WHERE id = 10;
id   multi_line_string
10    MULTILINESTRING ((61 2, 64 3, 65 6), (58 4, 59 5.,
 61 8), (69 3, 67 4, 66 7, 68 9 ))
