ST_PointFromShape takes an ESRI point shape and a spatial reference ID and returns a point.
st_pointfromshape (esri_shape bytea, srid integer)
In this example, the points are stored in the geometry column of the pts table, and the shape column is updated with their shape representations (using the ST_AsShape function). Finally, the ST_PointFromShape function is used to return the points from the shape column. The pts table has a geometry column, where the points are stored, and a shape column, where the points' shape representations are stored.
CREATE TABLE pts (id integer, geometry st_point, shape bytea);
INSERT INTO pts (id, geometry) VALUES (
10,
st_point ('point (44 14)', 0)
11,
st_point ('point (24 13)', 0)
UPDATE pts
SET shape = st_asshape (geometry)
WHERE id = 10;
UPDATE pts
WHERE id = 11;
In the following SELECT statement, the ST_PointFromShape function is used to retrieve the points from the shape column.
SELECT id, st_astext (st_pointfromshape(shape, 0)) AS points
FROM pts;
id points
10 POINT (44 14)
11 POINT (24 13)
