ST_SRID takes a geometry object and returns its spatial reference ID.
Oracle
sde.st_srid(g1 st_geometry)
PostgreSQL
st_srid (g1 st_geometry)
The following table is created:
Oracle
CREATE TABLE srid_test (g1 sde.st_geometry);
PostgreSQL
CREATE TABLE srid_test (g1 st_geometry);
In the next statement, an ST_Point geometry located at coordinate (10.01, 50.76) is inserted into the geometry column g1. When the ST_Point geometry was created by the ST_PointFromText function (Oracle) or ST_Point function (PostgreSQL), it was assigned the SRID value of 0.
NOTE: If you want to use an actual SRID value, either use one of your existing SRIDs and alter the coordinates to fit, or insert the spatial references given at the end of this example and run this example with the SRID you assign for it.
Oracle
INSERT INTO srid_test VALUES (
sde.st_pointfromtext ('point (10.01 50.76)', 0)
PostgreSQL
st_point ('point (10.01 50.76)', 0)
The ST_SRID function returns the spatial reference ID of the geometry just entered.
Oracle
SELECT sde.st_srid (g1) SRID_G1
FROM srid_test;
SRID_G1
PostgreSQL
SELECT st_srid (g1) AS SRID_G1
FROM srid_test;
srid_g1
Inserting a spatial reference system
Execute the following command to insert the necessary spatial reference system to your table, changing the SRID to the next available number in your table.
Oracle
INSERT INTO SDE.ST_SPATIAL_REFERENCES VALUES (
'GCS_North_American_1983',
{1 | <next srid>},
-400,
-400,
1000000000,
-100000,
10000,
-100000,
10000,
9.999E35,
-9.999E35,
9.999E35,
-9.999E35,
9.999E35,
-9.999E35,
9.999E35,
-9.999E35,
4269,
'PROJECTED',
NULL,
NULL,
'GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]',
'ArcSDE SpRef'
PostgreSQL
INSERT INTO st_spatial_references VALUES (
{1 | <next srid>},
-400,
-400,
1000000000,
-100000,
10000,
-100000,
10000,
9.999E35,
-9.999E35,
9.999E35,
-9.999E35,
9.999E35,
-9.999E35,
9.999E35,
-9.999E35,
4269,
'PROJECTED',
NULL,
NULL,
'ArcSDE SpRef'
