Updating geodatabase statistics in SQL Server databases |
| Release 9.3 | ![]() ![]() ![]() |
NOTE: Applies to geodatabases created with an ArcGIS Server Enterprise license only
ArcSDE geodatabases (licensed with ArcGIS Server Enterprise) stored in SQL Server databases can be set to update statistics automatically. To do this, leave the database parameters AUTO_CREATE_STATISTICS and AUTO_UPDATE_STATISTICS enabled. Disable autoshrink. If you don't do this, you will need to update statistics with a full scan on all tables involved in your system including the sde_state_lineages and sde_states tables. To update statistics with a full scan, use one of the following:update statistics <table name> with fullscansdetable –o update_dbms_stats –t <table_name> –m "with fullscan" –i <instance> –D <db>sqlmaint –S <server> –U <user> –P <pass> –D <db> –UpdOptiStats 100NOTE: The analyze command from ArcGIS does not perform a full scan when updating statistics.
