User permissions for geodatabases on ArcSDE database servers
Release 9.3
Note:This topic was updated for 9.3.1.
For ArcSDE geodatabases for SQL Server Express, users are added to the database server, then permission to work with geodatabases and datasets is controlled by assigning users and groups to predefined roles in ArcCatalog. The user or group in this case is a Windows-authenticated login that identifies who you are; a role defines the operations you will be able to perform.
The predefined roles and possible permissions given to users and groups are
None—No specific access to the geodatabase or the datasets in the geodatabase
Read Only—Can read data
Read/Write—Can read, write to, and create new datasets in a geodatabase
Admin—Can administer a specific geodatabase
Server administrator—Administers the database server; can create, control access to, back up, restore, compress, attach, and detach geodatabases on an ArcSDE database server
To learn how to grant or revoke these permissions, see Administering user permissions for ArcSDE database servers.
Only database server administrators can add or remove users. Users or groups must be valid Windows logins. When a new user or group is added to an ArcSDE database server, that user or group will automatically be available in all current and future geodatabases within that ArcSDE database server. In other words, once a user has been added to the database server, that user name will appear in the Permissions dialog box for all geodatabases and datasets on the database server.Learn more about adding a user or group to an ArcSDE database server
