Specifying the log file location |
| Release 9.3.1 |
ArcGIS Server records system messages in log files. When you suspect something isn't working right, you can examine the log files to see exactly what is happening with your GIS server.
You can specify where the server writes its log files or simply accept the default location in the ArcGIS Server installation directory, which is <ArcGIS Server Install directory>\Server\user\log for Windows and <ArcGIS Server Installation directory>/server/user/log for Linux/Solaris on the server object manager (SOM) machine.
If you're configuring a distributed installation of ArcGIS Server (where components of the server run on more than one machine), you will need to share the log directory and reference it using a UNC path or NFS path (for example, \\myServer\log or /net/myserver/opt/log on Linux/Solaris). You'll also need to make sure the SOM and SOC accounts have Read and Write permissions to the log directory.
