Network ports used by Manager processes |
| Release 9.3.1 |
The ArcGIS Server Manager System for the Java Platform utilizes a number of network ports for GIS Services and deployed applications. The following list of ports are the default ports that need to be open and available for these services. They are categorized by where they are found in the server configuration files. These can be changed to work within your server environment if necessary.
The server.xml located in $ARCGISHOME/java/manager/service/tomcat/managerappserver/conf is the configuration for the Tomcat server which hosts the deployed Web applications and Web services. The following ports are used:
Port # |
Purpose |
| 8300 | Tomcat Shutdown for Web Applications |
| 8399 | The connector port for deployed ArcGIS Web Applications |
| 8343 | ArcGIS Web Application Connector redirect port |
| 8309 | for the AJP/1.3 protocol |
The server.xml located in $ARCGISHOME/java/manager/service/tomcat/managerserver/conf is the server configuration for the Manager application iteself. The following ports are used:
Port # |
Purpose |
| 8100 | Tomcat Shutdown port for the Manager Application |
| 8098 | The connector port for the ArcIMS Manager Application |
| 8099 | The connector port for the ArcGIS Manager Application |
| 8443 | The Tomcat Connector redirect port |
| 8143 | SSL HTTP/1.1 Connector port for Manager Application |
| 8109 | for the AJP/1.3 protocol |
| 8143 | The redirect port for AJP/1.3 protocol |
| 8182 | This port can be used for a proxied HTTP/1.1 connector |
Managing ports on Linux/Solaris
You can view the ports that GIS Server uses on Linux/Solaris. Click on GIS Server tab. On the left side of the page, click Ports. The ports being used by ArcGIS Server will be listed. Certain port numbers are editable.
